Results 1 to 9 of 9
Thread: installing the m2-atx psu, in a land rover to be specific
    Jun 2009
    Hey, so I'm new to the whole carpc thing. I know my way around computers, but cars I have less experience with. I was wondering how hard it is to install the m2-atx before I went out and ordered one.
    I've read it has to be directly wired to the battery? so does this mean i have to find a constant +12v wire in the schematics and then start snipping wires and splicing in the various connections, or is there actually a plug akin to the atx connectors that I can just plug the power supply into?
    So far I've taken the intro level electrical engineering classes, enough to learn a bit about logic circuits and the like, is that going to be enough training to successfully install one of these things without blowing something up?
    I've looked at all the online documentation for these things, and there's not much installation info.
    Thanks for all the help, looking forward to learning something new
    Mar 2006
    Colorado, but Canadian!
    You need 3 connections. (1) A constant 12v source that can handle high current, (2) a switched 12v source, and (3) a good ground point that can handle at least as much as #1
    So to get #1, you run a wire from your battery to wherever the M2 is. To get #2, you usually find it under your steering wheel and since it is just a trigger wire, you can tap off of an existing wire in almost all cases. For the ground, you just find a good piece of metal on your car without paint/grease and/or other crud and secure it there.
    1.9in x 2.9in -- 47mm x 73mm
    Jun 2009
    thanks,
    so for the first connection, I have to connect it directly to the battery?
    How does one go about running a wire from the battery in the engine compartment to inside the car where the psu is? As far as I can tell, there aren't any openings to slip a cable through.
    Mar 2006
    Quote Originally Posted by snoboarder2k6 View Post
    thanks,
    you put it through the firewall. There are lots of wires going through already but they are all in use. You just need to add 1 more to the cluster.
    Jun 2009
    cool, thanks. That definitely clears things up a bit.
    Jun 2009
    Quote Originally Posted by 2k1Toaster View Post
    for #2 "a switched 12v source", thats pretty much your ignition wire right?
    any aftermarket deck has a ignition wire connected to it, instead of searching under the steering wheel, can u just piggy back off the ignition wire that is hooked to your aftermarket deck?
    Variable Bitrate csfile's Avatar
    Feb 2009
    Quote Originally Posted by jofresh View Post
    yup
    OP: Just a recommendation for #1...you should put an inline fuse
    Jun 2009
    I like that idea. alot.
    also, for a 160 watt power supply, we're looking at a 13-15 amp fuse, right?
    Elsewhere
    No. Any power wire that is switched on/off with the ignition is sufficient.
    Yup.
    Other likely sources are cigarette lighters, unused slots in the fuse block, amplifier turn-on leads.
    How about the Wiki?
  1. HOW TO: Getting your CarPC ready before installing it in your car.
    By xraycat in forum General Hardware Discussion
    Last Post: 09-13-2007, 01:53 PM
  2. How to Power an Infill G4 Unit using an ATX PSU
    By snakeye5 in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 06-20-2007, 07:52 PM
  3. Wtb :: M2 Atx Dc/dc Psu !!!
    By CoupeE46 in forum Classified Archive
    Last Post: 01-28-2007, 04:06 PM
  4. 24VDC in ATX PSU
    By Julian in forum General Hardware Discussion
    Last Post: 03-18-2001, 06:26 AM
  5. KeyPower DC-DC ATX PSU
    By katnip in forum General Hardware Discussion
    Last Post: 08-08-2000, 02:16 PM
Tags for this Thread
