+ Reply to Thread
Results 1 to 4 of 4
Thread: LM555 as variable frequency oscillator
    Dec 2007
    Hello!
    I need a circuit in which the frequency of LM555 astable multivibrator can be controlled externally I mean by the help of transistor etc. So, please guide what modification may be done in the attached circuit
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    What's the ultimate goal?
    What will it control?
    What will control it?
    A set of predefined speeds or variable?
    Dec 2007
    Actually I want to control the frequency by the help of R2R (ladder network), where the digital input value will increase/decrease the DC voltage of R2R network, so the frequency may be varied from 1Hz to 5Khz (i.e. My desired frequency). So what should I do?
    Mar 2004
    Florence Yall, BFKY
    That's a pretty wide range. Tone generator? You could always use a potentiometer for manual selection or digital pot for some other input. For momentary R2R, do it like steering wheel controls (each pushbutton and resistor in series). You probably already thought of that. Switching in sequence, maybe a NAND gate (google LED chaser circuit).
+ Reply to Thread
  1. Variable syntax questions
    By Iamthehor in forum FB Software
    Last Post: 02-25-2009, 10:58 PM
  2. radioshark and AMP
    By Fallout in forum AMP
    Last Post: 10-08-2007, 03:15 PM
  3. Getting current frequency from Radiator
    By portreathbeach in forum Software & Software Development
    Last Post: 11-28-2006, 04:50 PM
  4. found in fperrorlog
    By 510SX in forum FP Bug Reports
    Last Post: 09-21-2006, 09:01 AM
  5. yet another frodo install with problems.
    By Marsupial in forum FrodoPlayer
    Last Post: 08-27-2004, 07:28 AM
