Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: How in the world do i get my system down to the 180w PSU range?
    Jun 2009
    I seem to be at a complete loss as to how to power my car PC. I have done a huge amount of research reading and checking and cant seem to comprehend how you can make use of a 180 w or even 300w psu seeing as when you check the ampsXvolts on the OPUS 360W DC-DC ATX/BTX 12 rail is only 180 watts and using a PSU calculator I have determined that i need roughly 250 watts.
    So is that projected wattage of 250 not strictly on the 12 rail?
    If so what is using so much power?
    as a note i am converting a desktop AMD sempron CPU for my use as car PC
    is this the issue?
    Thank you more than you know for your help.
    I really cant wait to get this project off the ground!
    **EDIT**
    Heres prospective Specs
    So this is what I was able to gather from the label on the tower.
    TOWER SPECS
    AMD Sempron 3300+
    2.0 Ghz 1600 Mhz FSD
    128 KB l2 Cache
    HD: 160 GB ATA hard drive
    Mem: 512 MB DDR SDRam
    Modem: 56k ITU V.92
    Video: S3 UniChrome 3D
    Network: 10/100 Ethernet Lan
    PARTS
    -10.4 touch screen 10W draw
    -SoundBlaster Sound Card
    -CD/DVD Combo slot drive
    -GPS USB
    -OBD II USB
    -Ipod
    -HD Radio Serial
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    First of all I want to thank you for using a descriptive thread title... you have no idea how happy this makes me.
    Second, post your system specs so we can get a better idea of what you're trying to power.
    Tidder
    Try RevFE
    Jun 2009
    Update with SPECS
    Thanks Tidder.
    TOWER SPECS
    AMD Sempron 3300+
    128 KB l2 Cache
    Modem: 56k ITU V.92
    PARTS
    -GPS USB
    -OBD II USB
    -Ipod
    -HD Radio Serial
    Mar 2006
    Colorado, but Canadian!
    Well the CPU alone draws 62W from what I can gather. I don't do AMDs so I dont know what rail it takes from. But the other stuff is small in comparison. The screen and the HD are the other biggies.
    1.9in x 2.9in -- 47mm x 73mm
    Jun 2009
    What dose a normal mini ATX usally draw wattage wise
    Mar 2006
    Quote Originally Posted by danimal View Post
    A form factor doesnt have a typical power draw.
    I have had a P4 motherboard in ITX formfactor that took 80W+ for the CPU only. I have also had a microATX via C3 board which took less than 20W total.
    But most people seem to use 35W processors.
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    i am running the smae cpu with 1 gig of ram + a lot more..(check my profile) with a DSATX 220w
    Jun 2009
    @ Nomader
    Did that CPU come out of a actual tower or would it be the same one that would be found in a full size desktop tower?
    Apr 2006
    Greece
    @ Nomader
    i actually bought it together with a mATX board a couple of years ago..it is really a standard dektop cpu nothing special
    though mine is actually a sempron 2800+ but it is the same wattage i think
    Jun 2009
    Alright, so then is a setup like I described something possible to use on the same PSU as you are using? or dose it being a mATX board make it less of a wattage draw than a full size ATX?
  1. Unbelievable all in one system
    By WayneVanRooyen in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 05-05-2009, 10:25 AM
  2. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  3. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
  4. Inverter and PSU success
    By magnetik in forum Power Supplies
    Last Post: 09-22-2001, 08:19 AM
