Do you get POST? Or any beep codes?
Does the AMD Sempron need the 4 pin 12V power connector? If so, is that connected?
Also start by checking if the RAM is good. Then start testing other components by swapping them out with other components (swap in a different power supply or try the power supply on a working PC).
LinkBack URL
About LinkBacks
