Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Can I Change CPU and MOBO while not reinstaling OS
    Jun 2009
    I want to change from a ATX to MINI ITX, the board i found comes with Intel Core Duo T2500 2GHz 2M 667 SL8VP Processor, though i was previously using a AMD processor, so I was hoping that i could switch over my HD with the OS instaled on it to the new board and CPU and be ok, then i thought, yea right nothings ever easy.
    If you could help me out id greatly appreciate it.
    Elsewhere
    No.
    How about the Wiki?
    Newbie duster's Avatar
    Jan 2009
    as a tech I would say no, as the driver files are scattered throughout the registry and each board uses different and also similar chipsets which will casuse many issue all of which untroubleshootable. Most of them deal with the HAL which is a core component of windows this area never moves and other drivers get placed next to it. this doubling effect will cause less resource availability which some drivers and hardware will not share these resources and the BSOD will start happening. keep in mind some of this info is simplified but the core concept is there. As a side note there are repair installs but that is about as effective as fluffing your pillow it may work but it will go flat again in the near future or worse. As a rule of thumb if you want the most stable system dont be lazy do the work and keep your sanity.
    Jul 2009
    Depending on the OS you're using, changing the CPU and motherboard out might force you to get another license (windows XP and up), though that can usually be sorted out with a not-so-quick call to tech support.
    Technically, you CAN change the motherboard and processor without reinstalling the OS. I've actually done this exact procedure a couple of times under Windows and once under Slackware. It's a huge PITA though as you'll probably end up reinstalling the OS after the 75th inexplicable bluescreen or kernel panic.
    For the sake of your own sanity, I'd highly recommend a fresh install after swapping out a lot of major components.
    Jan 2009
    I see this question day in and day out dont get me wrong I have done it before but not often, normally within weeks you will have issues. And I have also done it to see if I could force it typically with the time wasted you can install and fully configure a new system, plus normally with a carry over os you end up reinstalling again anyways so you waste 4 times the time of a normal reinstall
    Jun 2009
    haha alright, i was just wondering seeing as i went through this whole process last week and was hoping i wouldnt have to do it again.
    So i should install the new MoBo and CPU then reinstall the OS?
    Jan 2009
    I typically will install the board and hardware then install on a new hard drive and then pull data off the old drive as a data drive being that this is a week old there is not much data to worry about ... I would just install the hardware and the use windows install cd to nuke the system and start from scratch.:music:
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Using linux: Yes.
    Using windows: no.
    Quote Originally Posted by mitchjs
    stop with the REINSTALLS, what do you think we got some lame-o installer!!!
    RevFE - Super fast, modular frontend. Most powerful skinning engine in existence. Strong enough for an i7 made for a fitpc.
    Just a shame I can't justify a carpc to use it on anymore.
    Jun 2009
    so the reinstall will reconize the hardware changes on its own and make the appropriate changes?
    Jun 2004
    Westminster, MD
    Nope. On linux you have to make the changes if any are even required (I've never had to make anything besides occasionally display changes), but the difference is that linux allows you to make the changes instead of (most of the time) blue screening so you can't even boot into windows.
  1. Help figuring out what's up... mobo, CPU, memory, or PS
    By jmbickham in forum General Hardware Discussion
    Last Post: 01-02-2009, 07:18 PM
  2. Testing the waters: mini itx p4 mobo and cpu
    By EsKALad in forum Classified Archive
    Last Post: 12-31-2005, 10:46 PM
  3. Mobo, CPU and power rail
    By MatrixPC in forum General Hardware Discussion
    Last Post: 11-15-2004, 10:19 AM
  4. FS: mobo, power supply, CPU etc just look!
    By dannn in forum Classified Archive
    Last Post: 11-01-2004, 10:52 PM
  5. Brand New Mobo and 2.53 Celeron CPU
    By CJ8501 in forum Classified Archive
    Last Post: 09-30-2004, 08:16 PM
