I don't know if you'll be able to avoid the "damn I needed wire/adapter/etc to finish".
Depends on how you plan on mounting everything. Looks like you have the basic PC components. But then you need to consider if you're mounting the PC in the back. If you are and you want to keep the DVD drive up front. Then you'd have to plan for that. You'll also need whatever bezels/mounts to fit the monitor into the car. I'm also assuming that you're not planning on GPS, bluetooth, or radio.
LinkBack URL
About LinkBacks
