Results 1 to 3 of 3
Thread: newbie needs help with m2 atx
    Jul 2009
    hi i have a few stupid questions. wondering if any one can help me out.
    1 how do i use a m2 atx 20 pin atx with a 24 pin atx motherboard?.
    second im looking at the m2 and i see where the amp turn on wire goes but i see 2 pins in the spot. do i connect the wire to both of these pins?. and whats the best way to connect it?.
    thanks for all your help.
    Jan 2008
    some motherboards are fine with only using the 20 pins, others don't like it so much, i would say to try it with a standard ac computer power supply if available(only becasue you could be unfortuante enough to get a bad m2, and using a known good ps will help solve part of the problem) and see what happens. if it doesn't work, than you will need a 20-24pin adapter cable to power up those last 4 pins.
    also, if you are using a board with a intel processor, make sure you are connecting the 4 pin processor power connector(if you need that cable, mp3car sells a adapater).
    Jul 2006
    In regards to the amp turn on, one pin is positive, the other is negative. The best thing to do is to use those to trigger a relay to turn on your amp(s). I tried running both my amps straigt from the positive lead, and it wasn't reliable.
    MSI K9N6GM
    1 gig RAM
    8" Lilliput
    Onstar GPS mod
    XM
    Visteon HDZ300
  1. hooking up amp remote wire to m2 atx
    By mm87 in forum Car Audio
    Last Post: 07-16-2009, 03:11 PM
  2. M2 Atx .. qmm wires?
    By GreenBeauty in forum Power Supplies
    Last Post: 04-17-2008, 11:03 PM
  3. M2 ATX power supply wiring question... 3 terminals
    By Snortonnorton in forum Power Supplies
    Last Post: 07-25-2007, 08:25 PM
  4. Did I break my M2 ATX?
    By CelicaGTS in forum Power Supplies
    Last Post: 04-29-2007, 05:36 PM
  5. m2 atx with hardoff=never
    By Nerd2 in forum Power Supplies
    Last Post: 04-10-2007, 09:53 AM
