please use search ... i have answered this twice already in the past 2 days.
anyway... my solution with a power inverter is: you have a 3 wire outlet, before you insert the power cord into the inverter, grab a single electric wire and strip one side of it, insert it into the ground output of the inverter then insert the power cord, which will also hold the stripped wire in the socket.
strip the other end of the wire and ground it to chassis...
what you are doing here is shorting 120VAC GRD with 12VDC GRD. i had absolutly no problem with this setup on my 07 tundra, and technically no car should have problems with it, however every vehicle is different, so for precaution remove the fuses that arent nessesary to run the car from the fuse panel inside the cabin, then replace them one by one and watch to see that all the devices are operating, if a fuse blows then disconnect this setup and try a different approach... thats the only approach that worked for me flawlesly.
good luck
LinkBack URL
About LinkBacks
i forget what kind of computer it is all i know is its slow and old... but he used a converter to plug it into 110v i believe but whatever i think this is where my noise is coming from...
