Results 1 to 10 of 11
Thread: Did I just Bork My M4-ATX
    Apr 2008
    Wasn't paying attention and hooked up - to + and + to -.
    Pretty stupid. And now my M4-ATX keeps blowing the fuse.
    Is there something other than a borked PSU that could be causing this?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    can you see any parts that are fried? Any smoke?
    Live mp3Car Facebook Chat
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Probably fried. Take a look on the M4 to see if there is an integrated fuse. I don't think there is, but you never know.
    If you shredded it, chalk it up to experience. I zapped a $500 LCD from static electricity on the carpet. Everyone does it at some point.
    Want to:
    Apr 2008
    There's a fuse on the M4, but that was blown too. I'm looking for something other than that?
    Dec 2008
    you might be able to rma it if its under warranty. i know it was your fault, but it probably wouldnt cost them much to fix it and im sure they would want a happy customer. to be honest that power supply should have reverse polarity protection, its a little lame that it doesnt.
    Aug 2009
    Port Charlotte, FL
    Quote Originally Posted by trader007 View Post
    I can sympathize with the designer here. Reverse polarity protection is hard to do at the high currents and low voltages that we're dealing with here. Just guessing, but I'd say that supply will easily pull 15-20A on the primary side under peak load. There aren't many diodes that will pass that without having a VF of a volt or more, which would degrade the supply's ability to operate during low battery voltage conditions.
    Dec 2008
    Quote Originally Posted by joe_p View Post
    youre right. even to do it electronically "soft start" would be expensive too... its a tough call though, because since its not a proprietary hookup its always easy to connect it in reverse. you would think there is some cost effective way to stop a complete system meltdown in case of this...
    Apr 2008
    It's called not being stupid. Dang. I'm so po'ed at myself.
    Thanks for all your help.
    Oct 2006
    we all do it, i broke my xenarc doing the same thing. Its a good lesson learned, now i check polarity with every plug!
    Apr 2008
    Wouldn't you know it....I bought a new M4-atx, hooked it up and the fuse blew.
    I completely unhooked *all* my connections, re-hooked it up, and the old one works.
    I really hope I take my time and shake off these moronic moments.
  1. Everything You need to know about your M4 ATX
    By Fox_Mulder in forum Power Supplies
    Last Post: 09-10-2014, 02:36 PM
  2. Review: M4-ATX 250 Watt Intelligent Power Supply
    By Bugbyte in forum The Review Palace
    Last Post: 12-21-2009, 09:52 AM
  3. m4 ATX power supply question
    By icet in forum M4-ATX
    Last Post: 07-23-2009, 10:43 AM
  4. M4 ATX problems and questions
    By Dgr8wun in forum Power Supplies
    Last Post: 01-31-2009, 01:00 PM
  5. M4 ATX Turn On Problem
    Last Post: 12-31-2008, 08:43 AM
