Results 1 to 3 of 3
Thread: Tire pressure monitoring...but for air suspension..?
    Feb 2009
    I have a quick question about this kit;
    http://www.mp3car.com/index.php/213-...MS-Review.html
    It seems that it monitors the pressure in all 4 corners; which is exactly what I would need to do for my Air suspension. I rather have a picture (outlined) of my car on my dash embedded into my carputer rather than 2 ugly gauges.
    The problem is with this kit the sensors are in the valves if I am correct in my research? So I am wondering how I would go about converting this kit for air suspension (in which I would have to plumb the sensors in line with the bag (t fitting)
    Not sure if this has been done before or not or if there is a kit for this?
    Nov 2004
    St Louis
    A cheaper and easier option would be to use a Fusion Brain with sensors from Dakota Digital. This is more of a plug and play option that won't require any special mods to your air systems. I have only the one 400PSI sensor screwed directly into an unused port on my tank. Check out these threads:
    My air ride suspension FB diagram
    150 PSI Air Pressure Sensor
    http://www.mp3car.com/vbulletin/fb-d...uspension.html
    Quote Originally Posted by Jester2893 View Post
    Feb 2009
    Those links helped a bunch thanks!
    I am confused about if I need pressure senders (the Dakota ones) or do I just relays, because in of the links it looks like the diagram just shows relays?
    Is there a more in depth tutorial as far as the actual wiring of the system goes? Also am I able to do 5 inputs (one for each bag and then the tank pressure..or no?)
    Also I would be all to skin my own car correct?
  1. Custom USB tyre pressure monitoring interface
    By Robby BMW in forum Portal Media Car PC Gadgets and Accessories
    Last Post: Yesterday, 08:57 AM
  2. RRTMS - RoadRunner tire monitoring system extension plugin
    By Robby BMW in forum RR Released Plugins
    Last Post: 11-08-2012, 01:25 PM
  3. detecting tire pressure
    By st_claire in forum User Innovations
    Last Post: 12-21-2009, 10:54 AM
  4. Tire Pressure Monitoring System
    By vinzer in forum DigitalMods (Scripts / API)
    Last Post: 02-22-2008, 12:39 AM
  5. RS232 Tire Pressure Monitoring System
    By jcampbell in forum General Hardware Discussion
    Last Post: 12-11-2006, 05:17 PM
