Results 1 to 8 of 8
Thread: Hard drive problems help please
    Jan 2009
    Hey guys
    I can't believe i'm asking this question...but i don't know how to install my 2.5" sata hard drive to my motherboard which is (Via Epia M 10000G Motherboard) can someone please tell me how to connect cord by cord and name them...or if you have a diagram or picture that would be good, just anything will help Please
    Elsewhere
    Simple answer: return your SATA hard drive and get a PATA (parallel ATA, also known as ATA or IDE). You will probably need an adapter to connect a 2.5" laptop drive to a desktop motherboard such as the M10000.
    And next time read your specifications very, very carefully so you purchase compatible parts.
    You may also be able to get by with one of these: http://www.cooldrives.com/satoidecofor.html.
    (Low profile model pictured on a 2.5" HDD)
    I haven't used one, so I can't say how well they work or not, but it's supposed to do what you need. If you're trying to cram all this into a Voom-style case, forget this adapter and just exchange the HDD. There's simply not enough room in the case for a circuit board of this size hanging off the back of the HDD.
    Never mind the increased potential for the adapter to work its way loose in the harsher environment of a moving vehicle with bumps, bruises, vibrations, etc.
    To the rest of you Newbies to the vehicle computing hobby... Heed this warning:
    PLAN YOUR SETUP IN METICULOUS DETAIL BEFORE YOU PURCHASE ANY PIECES/PARTS!!!
    It's a mantra that has been preached here as long as I've been coming around.
    Careful, thorough planning of your entire installation will help you avoid these little hiccoughs.
    How about the Wiki?
    Jan 2009
    I do have a 2.5 adapter but it just doesn't fit my laptop sata hard drive what do i do then.
    Elsewhere
    What adapter do you have? Is it specifically to use a SATA hard drive on a PATA interface?
    Does it specifically state that it will fit on a 2.5" laptop style HDD?
    Honestly, I think your easiest solution is to return the SATA HDD and adapter and just get a PATA HDD. Your life will be a lot easier, I assure you.
    How about the Wiki?
    Jan 2009
    yeh yeh it says 2.5" HDD adapter so why wouldn't it fit
    Elsewhere
    Without seeing the adapter, I have no way of knowing. Got a link? A pic? Something more than just a description?
    And you said it's for a 2.5" HDD... Are you certain it is for a SATA hard drive to connect to a PATA interface?
    How about the Wiki?
    Jan 2009
    MY BAD EVERYONE
    DarquePervert Thank you so so much for your help...l'm just going to buy a PATA and return my SATA...Im an idiot
    Variable Bitrate mayhembdm666's Avatar
    Mar 2008
    Adelaide, Australia
    So i take it that it was a 3.5 to 2.5 IDE adapter?
    Just to help out other people on the forums, what was the issue?
    2004 Holden WL Caprice Auto GENIII
    Base System = Raspberry Pi
    Everything else is pending for now as switched from a Mini-ITX setup
  1. Slim dvd drive problems. JAE 50pin to IDE at fault?
    By 2k1Toaster in forum General Hardware Discussion
    Last Post: 08-16-2007, 05:06 PM
  2. hard drive problems?
    By hot_98_civic in forum Newbie
    Last Post: 06-01-2005, 09:24 PM
  3. Did you know "single" Hard Drive Booted Faster?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-03-2004, 01:50 PM
  4. carputer hard drive died in 3 days
    By therussman2002 in forum General Hardware Discussion
    Last Post: 08-10-2004, 02:49 PM
  5. All-electronic flash drive and solid state hard drive
    By Typhoon747 in forum General Hardware Discussion
    Last Post: 12-12-2003, 03:20 PM
