No comments or anything? Am i possibly posting in the wrong area?
Okay so tell me what you guys think of my setup, or any issues that i may run into.
Mobo:
ZOTAC N230 ($140)
Screen:
Thinking about going with this: (because i don't want to do any fabrication)
http://store.mp3car.com/Double_Din_B...h-016-0001.htm
Any issues with this monitor?
Case: (might not need it)
M350 ($40)
Memory:
1 Single DDR2 667 ($30)
PSU: (not sure, need help on this)
M3? Will this be able to power it, i think its a 24pin on the mobo? ($70)
Hard Drive:
WD 2.5 Sata 120gb ($Free, had it from something else)
Wifi:
Possibly this?> http://www.newegg.com/Product/Produc...82E16833130111 ($23)
Can anyone find me a wireless N card though? (usb)
For my keyboard, i have this palm bluetooth fold up keyboard, so sick!
For gps, i have a bluetooth receiver, have a feeling its going to get messed up if i have the keyboard connected too, i believe it has a usb hookup too.
For internet on the go, got my HTC diamond, usb cable, charge and go, u kno.
So what you guys think? Comments pls![]()
Will add a backup cam, OBD, Slot load later on. also, possibly 2 headrest monitors for the backseats, only for movie/video watching.
Pic of the area of install:
2009 Altima 2.5S CVT Dark Slate
Don't rush, answers will come when they have to come
D945GCLF2
Mobo:
D945GCLF2 I prefer it, maybe its not so graphically accelerated but your overall performance will be better.
Screen:
Your choice, but considering your car's dash, you WILL need to do some fab, it doesn't have the 2 dins available (at least for what i see)
Your choice
Memory:
Go for 2G memory is cheap nowadays
Can't say yet.
Hard Drive:
Anything would be good, if you want to go excellent search for intel x25-e SSD mwahahahaha
Wifi:
everything is the same.
You still need to think on powering, grounding, your usb extensions, maybe a cheap GPS.
Download riderunner or centrafuse and toy around with what they do, it will give you an idea of what you would like to install.
REQUIRED HARDWARE [50%]
CARPUTER INSTALLATION [0%]
LCD IN DASH FRABRICATION [??%]
Additional mods:
KNIGHT RIDER LED MOD:[99%]
Worklog Album
The Zotac N330 would be a better choice, and it comes with 802.11n Wi-Fi.
http://www.newegg.com/Product/Produc...82E16813500030
I've just started my car pc project using the Zotac N330 board. Used 2gigs OCZ plat. and a WD 2.5" Scorpio Blue 400gig HD.
Windows 7 installs and runs great on this setup for dedicated tasks. It gets a bit sluggish when you start opening a lot of programs, but for a carpc, that shouldn't be a problem.
It plays back 1080p x264 files with about 20-25% CPU perfectly!
Went with the m2-atx for power and the 4th gen mocoso case. Very happy so far.
Rob W.
Thanks for the replies guys, ARN: I forgot to list, but i will be getting 2gbs for that cost, my car is able to do a double din, i've looked into it, you buy another faceplate thats used for the model with navi, only reason i was thinking about wasting money on a case is to just be able to pull it out if need be, thats a last buy of courseHD: Not trying to spend that much, trying to keep this cheap
I'm not too worried about grounding and powering right now, i know most of that pretty well, wifi, i do not want a built in card, because this is most likely going in the glovebox.
The wifi in the Zotac 330 board is a mini pci card that is removable. It also uses an external antenea that I'm sure you could buy a cable for to mount somewhere else.
Rob W.
The zotac board is really compelling, but
1. I am a cheapy guy![]()
2. even tough it is not a big deal, intel has a software called "intel integrator toolkit" you can ad your custom bios POST screen, so you can give it a little "show off" factor when the car starts.
Additional mods:
Worklog Album
Well, in your original post, you were saying you were going to spend $140 on the Zotac N230, plus $23 on a USB Wi-Fi. The Zotac N330 costs $170, or $7 more than the combined cost of the N230 + Wi-Fi. For the extra $7, you get: double the CPU power (dual core vs. single core), and internal Wi-Fi with an external antenna connection, which means you don't have to worry about the external Wi-Fi box.
For external antenna, I use this one: http://www.data-alliance.net/-strse-...unt/Detail.bok . It isn't as big as it looks in the picture, it's only about as tall as a 20-oz Coke bottle. But having the antenna outside your vehicle makes a difference.
However, if you want to go cheap, then get the Intel D945GCLF2. Dual core Atom 330, but Intel graphics instead of NVIDIA. Only $84 at Newegg (or $59 open-box special), instead of $170. Or the D945GCLF, single core Atom 230, $65 instead of $140. Neither include Wi-Fi.
