Results 1 to 10 of 15
Thread: Motorized LCD Idea
    Sep 2009
    Motorized LCD Idea
    The black curved part represents the dash. Ineed the screen to slide out then rise up to viewing angle. I would like it to slide down for a better position but that seems very difficult.
    Does this look like it will work:
    Black= Antenna base
    Blue= Antenna "arm"
    Red= LCD
    Greens= Mounting Arm
    Light Blue= Hinges
    Yellow= Rails/Sliders
    Step 1 Everything starts sliding out:
    step 2 The slider hits stopping point:
    Step 3 Actuator pushes screen into up position:
    Oct 2008
    only problem i could see arising is the section (or size of) dash needed to be removed in order to allow the screen to flip up
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    On step 3, the actuator won't work. Or rather, it will work sometimes and other times it won't. Because the short green mounting arm is underslung it could just as easily make the screen fold DOWN rather than up.
    I think if you simply eliminate the short green mounting arm and connect the antenna arm directly to the hinge that the short green mounting arm is connected to in your diagram, it will work better.
    That will make the antenna arm be at a slight angle which will be much more likely to push the screen up.
    Also, use an L bracket and bolt it to the side of the monitor and move the hinge point inside your track. Like this:
    Want to:
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Stockholm, Sweden
    What is wrong with existing single DIN units?
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    The issue with most single DIN motorized units, is that they tend to stop working not too long after the guarantee runs out. Specifically the plastic gears break. This would solve that issue, but generally linear actuators are expensive, have you found a cheap source?
    Quote Originally Posted by mitchjs
    stop with the REINSTALLS, what do you think we got some lame-o installer!!!
    RevFE - Super fast, modular frontend. Most powerful skinning engine in existence. Strong enough for an i7 made for a fitpc.
    Just a shame I can't justify a carpc to use it on anymore.
    Sep 2005
    Stockholm, Sweden
    DC motors are small and cheap and so are threaded rods....
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    It looks like he's using a power antenna as the actuator. For awhile I thought it was an LCD with built in WiFi!
    Want to:
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by bes51659 View Post
    Right, but you have to build a controls system or use limit switches and a lot of people don't really know how to do that.
    Want to:
    Sep 2009
    Yeah I don't know how to program servos and what not. I could buy a single din LCD but...
    The screen I will be using is 12" and it's not coming out of the stereo opening it will be replacing the vents in the center of my dash.
    After thinking about it real hard I think I'm going to attach the antenna/actuator to top of the screen and the rails that guide the screen on the top/sides. So the screen will come out and gravity will let it slide down. I will draw up something and post it in a bit.
    Thanks for all the info and input though.
    Sep 2009
    So here is my new idea I think it is simpler. I will have make the antenna/actuator rotate to move the screen up (I think)
    Step 1
    Step 2
  1. FAQ: LCD Technologies
    By dontpntpool in forum LCD/Display
    Last Post: 03-15-2007, 01:20 AM
