No need to worry. Dual voice coil configurations give you more wiring options and flexibility over single voice coil subs.
Yes, your amp is capable of putting out a lot more power than the sub is capable of handling.And the sub AMP is a DynaBel BF4501 -1X1200 Watt RMS.
It says its 1x450 watt RMS at 4Ω, its also stabile at 1Ω = 1200Watt.
Do this mean that my amp can handle 3x the power thats max on my sub?
(ill link it, its in norwegian, but you should be able to get the numbers atleast "utgangseffekt" = "load (?)"
Yes, use option 2.Anyways, does this mean that i have to use this wiring setup? (option 2)http://www.rockfordfosgate.com/rftec...1&woofer_imp=3
LinkBack URL
About LinkBacks
