Very likely not. Eonon probably used a lower quality screen that will not support computer resolutions, so any text on the screen might be harder to read. There is also the issue of where the screen controller is located(the thing that tells the screen what to do)- if it is not a separate module(on the main pc board), you will either need to create your own or find someone who can. And that is just a idea of some of the issues that you could run into- you might get super lucky and it will be easier, or it could be much worse.
Would it be worth it for most people? No. Though I can't say if it is or not for you.
LinkBack URL
About LinkBacks
) with a screen on the way out
