Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: N00b help with laptop setup
  1. #11
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    The way you can test this is to use a digital multimeter and check for continuity across the pins, then press the button and see if you get continuity. If you do, those are the pins.
    Want to:
  2. #12
    Nov 2009
    for power would a charger that plugs into the cigarette lighter work? or would it not have enough power/be dangerous? i am going to take the laptop out everyday and charge it during the night and just need something to charge it if i absolutely need it.
  3. #13
    Jan 2008
    it should work ok. if you are going to use a inverter, and then use the power cord that came with the laptop, you might run into noise issues from the inverter-- but the only way to know would be to try it and if you do have noise problems, look at solutions at that point
  1. New Laptop Project!
    By LeeVD in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-22-2007, 12:59 PM
  2. What could cause this problem? (laptop related)
    By Rocky388 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 09-17-2006, 03:17 PM
  3. COMPAQ laptop setup
    By omlax19 in forum Classified Archive
    Last Post: 08-03-2005, 11:08 AM
  4. can you use a laptop screen for a mp3car setup?
    By brandondere in forum General Hardware Discussion
    Last Post: 03-21-2001, 09:41 AM
