Results 1 to 7 of 7
Thread: Newbie with power question
    Newbie patsfanwilly's Avatar
    Nov 2009
    Central Kansas
    Hello everyone. Im going through the design of the carputer i just purchased for my truck. I would like some feedback and suggestions on power to the carputer. The basic setup starts like this. 4 gauge streetwires cable to a streetwires distribution block (FBXM68). 8 gauge out to the carputer. My question is should i still put a fuse holder close to the battery or after the distribution block.
    Newbie envy's Avatar
    May 2008
    Always put a fuse near the battery. That's a must. I also recommend a distribution block that is fused.
    ][ Still Building ][
    <>Intel 945GCLF
    <>160 gb WD sata 2.5"
    <>1 gb 667
    <>M2-ATX 160W
    <>ATI Radeon 7000
    <>Antec Mult-Station Premier Deluxe IR receiver and remote
    <>Windows XP Pro, and CF as front end
    <>7" LCD Myron Davis
    Elsewhere
    Quote Originally Posted by patsfanwilly View Post
    Yes and yes.
    The fuse near the battery will protect the wire from the battery to the distro block.
    The fuse after the distro block will protect the wire from the distro block to the equipment.
    In your case, the distro block has fuses for the wires to each component, so you don't need a fuse holder after the distro block. The distro block has that built in.
    How about the Wiki?
    Nov 2009
    Central Kansas
    Quote Originally Posted by DarquePervert View Post
    Yes and yes.
    thanks guys thats kind of what i figured but i wasnt for sure. The other question is what size of fuse should i use at the battery and at the distribution block. Ill be running a mcs Generation 2.0GHz C7 carputer with a Lilliput 629GL.
    Jan 2008
    what power supply will you be using?
    i really don't think that it will be over 30 amps, but it would be safer to get the fuse rating matched as close to the standard current draw of the devices as possible.
    Nov 2009
    Central Kansas
    Quote Originally Posted by soundman98 View Post
    Ill be using the m2-ATX
    Newbie Moysie's Avatar
    Oct 2007
    Fife, Scotland
    Blog Entries
    1
    Hi,
    For an installation such as yours i would probably choose a fuse size a few amps under the maximum current rating of the main cable for additional safety, Regardless of the total draw of each device at this point.
    The purpose of this fuse is to protect the cable.
    At your distribution block however i would match the fusing to the load of each individual device. Also ensuring the correct size of cable is used from the dist block to the device.
    Note: THE FUSE MUST ALWAYS BE THE WEAKEST LINK IN THE CIRCUIT
  1. Review: M4-ATX 250 Watt Intelligent Power Supply
    By Bugbyte in forum The Review Palace
    Last Post: 12-21-2009, 09:52 AM
  2. 2007 Ford Fusion Carputer (version 2.0)
    By FusionFanatic in forum Show off your project
    Last Post: 04-20-2009, 05:56 PM
  3. Newbie Question DC Power
    By Nickwell24 in forum Newbie
    Last Post: 03-07-2008, 03:42 PM
  4. Newbie with power ?s for monitor
    By sengd001 in forum Newbie
    Last Post: 06-05-2006, 05:48 PM
  5. XBOX, Carputer, power Question! ELECTRIC GURUS HELP!
    By EggrollXpress61 in forum General Hardware Discussion
    Last Post: 08-21-2004, 12:15 AM
