Results 1 to 10 of 12
Thread: questions on tweeters
    Nov 2009
    hihi. i'm a noob trying to upgrade my car tweeters. i have a crossover network wired up already.
    can i ask if any of you guys tried to fix some of these non-car tweeters in your car?
    like this one:
    http://www.parts-express.com/pe/show...number=279-140
    they are alot cheaper. and seem for value for money than car tweeters.
    thanks!
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    They will probably work but you got to look at (among other things) the impedance of the speaker as compared to what your amp or HU can handle.
    I'm rusty on which impedance car speakers are (either 8 or 4) so you might want to find that out and compare it to this speaker.
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    most car speakers are 4-ohm, some higher end ones are 2-ohm. 8-ohm is common for home speakers
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Most car stuff is 4ohm, whereas the PE drivers are typicalls 6 - 8 ohm. If you know what you are doing, you can potentially piece together a system that will cost significantly less than a store-bought product. I built my own component speaker system from PE for ~$100 with some higher quality caps, inductors, dayton tweeters, and audax aerogel midbass. It's 6 ohms, but runs off my amp just fine. But if you are adding a tweeter to an already designed crossover network, then make sure the impedance matches otherwise your freq curve will change.
    Nov 2009
    Quote Originally Posted by nobb View Post
    that's quite awesome!
    Jan 2008
    that reminds me, i need some new mids....
    alot of people have used large format tweeters like that. IMO, the largest hurdle to overcome is mounting it-- because they are just so big--once you get it mounted though, the change in resistance can be compensated for with different settings.
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Yea most of the PE tweeters are huge. Take a look into the Dayton ND20FA tweeter, that's the one I use. I picked it because it's very small and you can mount it from the surface.
    Nov 2009
    that's very nice....but.
    it's 6ohms. my crossover came with 4ohms. so what do i need to do?
    Oct 2009
    I run Selenium tweets and mids in my "monster PT" they are 8 ohms and very efficient, I run them off of a 4 channel amp 115 per side but less since the 115rms is 4 ohms, they get very loud!
    I also run Dayton mids and Vifa tweets up front, but they are 4 ohms mdels.
    8 ohms tweets are fine, as long as you keep the crossover point safe for them and watch the efficiency of them, usually pretty high.
    Nov 2009
    can i ask at what freq did you cross it over?
  1. Alpine PXA-H701 Questions
    By unixxx in forum Car Audio FAQ
    Last Post: Today, 02:48 AM
  2. INFILL G4 - Australian and New Zealand Questions Answered
    By INFILLG4 in forum General MP3Car Discussion
    Last Post: 04-30-2008, 12:21 AM
  3. Replies: 8
    Last Post: 03-25-2007, 10:20 PM
  4. Replies: 4
    Last Post: 12-29-2006, 01:16 PM
  5. Amp and Speaker Questions
    Last Post: 02-24-2006, 05:52 PM
