Results 1 to 3 of 3
Thread: Trying to get started...
    Nov 2009
    Alright - sorry for making a new thread just to ask questions about my build but I'm planning on making postings logging my build as well so I'm figuring the thread can just be moved when the time comes.
    Anyway, great site lots of info. I read through a whole bunch of topics and I'm trying to figure out exactly what equipment (and, especially, what software) I'm going to need to make this thing work and make it look "baller".
    I own an 02 Acura RSX Type-S (black if anybody's curious). I've done a handful of mods across the spectrum - performance, vanity, and of course my stereo. Most recently I had my ECU modified for USB programmability (the other Honda guys will know it was Hondata KPro). I won't go into the fine-grained details but this thing lets the user alter just about any ECU setting and monitor any sensor.
    My other purposes will be to play my MP3 library and I'd like to integrate a GPS so I can get rid of the Tomtom that's suction cupped to my windshield. It makes it a pain to keep the windshield clean. I'd like to build a low-power system - minimal specs to run what I want to run without having the system sit there and chug, that way it's not drawing too much off the battery/alternator and ruining my mileage (or my battery).
    That's what spurred me to get this idea into the planning phase. There's another feature that allows you to make a gauge display (with a form designer similar to a Visual Basic or .NET GUI designer), and I don't really like having to look over at my laptop on the passenger seat to see them, I'd rather be able to still see the road out of my peripherals when I glance down for a second.
    I've been trying to put together a list of what exactly I'm going to need for this. I'll have a double DIN space available to me - I've read that the Lilliput 7" screens fit almost perfectly and I saw a couple builds that made them look pretty much perfect with a $24 dashboard mounting kit for the RSX. So I've got that covered.
    Everything else I'm a bit confused on, though. I'm very familiar with computers and building, so I've got a pretty good idea of what I need, specifications-wise - I'll be running XP, so probably half a gig to a gig of memory and a 1.5-1.8GHz processor, and probably a 32gig SATA SSD for quick startup.
    But that leads me to further questions...for my purpose, what would be recommended as far as the actual parts? My first inclination was to use Nano-ITX, but trying to comb through their site and figure out what I need really ended up fruitless.
    I'm also not really sure how to get the speakers hooked up - everybody's said to use amplifiers, but I'd like to avoid having another device drawing power. I've already got an aftermarket head unit, and as a result, a wire harness adapter - would it be possible to use 1/8" -> RCA adapters, and then behead the other end of the RCA wires and solder them to the harness adapter's wires? In addition to computers I do a lot of low-level A/V stuff for work, and in my experience these analog A/V signals are generally all compatible with one another.
    Anyway, sorry for leaving this novel here...extra props to anybody who reads it >.>
    Jun 2008
    Seattle, WA
    I'd recommend a Mini-ITX motherboard with a dual-core Atom 330, such as the Intel D945GCLF2D.
    As for amplification, does your car have a factory amplifier? If not, then you will need to add an amplifier to your setup. The headunit you're taking out has an amplifier built into it, but computers do not.
    -- Kevin
    Jan 2008
    what your talking about doing-- removing the rca plugs on the aftermarket/factory adapter cable---this would only work if you have a factory amp that is expecting a low level signal. if you have to hook up the speaker level outputs of the deck to the amp, it will be easier to just get a small motorcycle ampt to power all your speakers.
  1. I'm back, finally gettting started on 3.0!
    By Arby in forum General MP3Car Discussion
    Last Post: 06-18-2007, 08:17 PM
  2. New carputer project started - 350z (56k beware)
    By StutterinJ in forum Fabrication
    Last Post: 05-22-2005, 08:45 AM
  3. I finally started console fabrication
    By gadget in forum Fabrication
    Last Post: 04-06-2005, 11:02 PM
  4. Started Carputer, having Opus problems?
    By shuluke in forum Power Supplies
    Last Post: 01-20-2005, 02:57 AM
  5. Ya I have started building!
    By generalgman in forum General Hardware Discussion
    Last Post: 02-16-2001, 02:17 PM
