Results 1 to 5 of 5
Thread: Newbie VGA touchscreen questions....
    Oct 2009
    Ok, if the CPU I plan to to run has a VGA port for use with a monitor, is VGA touchscreen compatible? Or only for non-touchscreen monitors?
    Jun 2009
    most touchscreens has at least 2 connections to the pc
    1) graphic signal (vga/dvi) output from pc, just like any screen
    2) usb HID input to pc, like your mouse but require driver
    Oct 2009
    Quote Originally Posted by Banegio View Post
    Thanks, I have usb ports as well so I should be ok. I thought that there was more than just the VGA connector, but was unsure.
    Jul 2009
    Quote Originally Posted by ptcary View Post
    Just an FYI: CPU = Processor (Computers Brain) it doesnt have the VGA Port. Eiter your motherboard or a GPU (Graphics Card) are the ones with the VGA Port.
    Using the wrong terminology can get confusing to the people helping you out (not in this case) and you then get wrong answers.
    Yea you should be ok with that. you might have to install a driver before it will work properly though.
    '93 Toyota Celica - First Car PC install
    Current System Specs:
    ZOTAC GF8200-C-E AM2+ GF8200
    AMD Athlon 64 X2 3800+
    1 GB DDR2 667
    LITE-ON DL-8ATS Slot-Load
    750 GB Seagate SATA HDD
    250W PSU
    19" Hyundai Monitor
    Elsewhere
    VGA is a minimum resolution of 640x480 pixels.
    A screen capable of displaying VGA resolution is basically a high-quality standard-def television.
    A screen capable of displaying VGA resolution does not necessarily mean that it has a PC VGA connector.
    READ YOUR SPECS CAREFULLY BEFORE YOU PURCHASE!
    Look for a screen that has a 15-pin DSUB connector (also known as a 15-pin VGA connector).
    How about the Wiki?
  1. Hardware Review: Provision 8" 16:9 VGA Touchscreen
    By lightman in forum The Review Palace
    Last Post: 06-15-2009, 09:02 AM
  2. Replies: 8
    Last Post: 03-25-2007, 10:20 PM
  3. Replies: 0
    Last Post: 10-07-2006, 10:37 PM
  4. FS: Lilliput 7" VGA Touchscreen BRAND NEW
    By spicmonster in forum Classified Archive
    Last Post: 06-19-2006, 12:16 AM
  5. Replies: 3
    Last Post: 04-03-2004, 11:21 PM
