Results 1 to 8 of 8
Thread: What PSU Should I use?
    Nov 2009
    I have the motherboard from a HP Pavilion A815N (P/N-518739, Intel Pentium 4 CPU 3.06GHz, 2 GB Ram. I would like to know what PSU I can use with the board.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    m4 or dsatx.. or the high end opus unit. Those are pretty much your only option
    Live mp3Car Facebook Chat
    Nov 2009
    Thank you for the information. Now the equipment that has been recommended, am I able to purchase this from the mp3car store? Also, is it better to run a DC - AC inverter or to just switch out the power supply?
    Nov 2009
    Now can I get these iteam here in the store? Is it better to just run an AC-DC inverter?
    Jan 2008
    Quote Originally Posted by manishwayz View Post
    Now can I get these iteam here in the store? Is ibetter to just run an AC-DC inverter?
    noooooo! if you can afford a dc-dc solution, please do not even consider a dc-ac-dc solution(because that is really what a invertor setup is doing). simply using a dc-dc power supply will be eliminating many problems that invertors could cause(i say 'could', because not all invertor installs have problems, but there is no way to know until after you have purchased the inverter..).
    Nov 2009
    Thank you for all of the helpful information! Which of the DC-DC psu's is better to use m4, dsatx or opus unit? I want to avoid any problems.
    Jan 2008
    that is a matter of opinion-- i have a dsatx, so my answer is obviously biased that way, and other members with the other ones will be just as biased...
    try to find a power supply calculator(like the one listed in the adv. faq at the topof the page...), and find which power supply will best fit your needs.
    Nov 2009
    Ok here is what I plan on running: Asus PTGD1-LA (from HP Pavilion A815N) with an M4-ATX 250W Intelligent DC-DC PSU. Will that psu work for me?
  1. FAQ: How do I power my DC-DC PSU on my workbench?
    By DarquePervert in forum The FAQ Emporium
    Last Post: 12-14-2011, 07:55 PM
  2. Remove Case DC-DC PSU?
    By Uther in forum Power Supplies
    Last Post: 08-27-2006, 11:33 AM
  3. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  4. Mastero 3.5 12v-12v PSU KIT fs
    By SteveC in forum Classified Archive
    Last Post: 09-28-2004, 12:04 PM
  5. Powering up normal ATX PSU
    By KimaX in forum Power Supplies
    Last Post: 09-28-2004, 01:08 AM
