Results 1 to 9 of 9
Thread: quick question about using a larger fuse on alpine amp
    Nov 2009
    ok im going to be installing an older alpine amp in my car soon. the manual says to install a 25 amp fuse. would using anything higher be detrimental? or should i strictly use a 25 amp fuse? most install kits come with at least a 30 amp. its not a problem to buy a 25 amp one just want to be sure.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    If it says to use 25, then use 25. Going bigger means providing less protection for the system.
    Want to:
    Nov 2009
    alright thanks just what i wanted to hear
    Jan 2008
    if there is a 25 amp fuse on the amp, i don't feel that it is too big of a deal to run a 30 amp fuse at the battery (this would is primarily for 'worst case scenario' things-- you get in a wreck and the power cable gets cut/pinched...). if the amp is not fused(as some aren't...), i would highly recommend using only what they recommend, any higher could allow the amp to hurt itself.
    Nov 2009
    thanks guys
    Raw Wave
    Nov 2009
    As per soundman and others - if the unit has its own fusing - which it will have (surely!?) - the upstream fuses are irrelevant.
    Equipment fusing is to protect itself (else fail in a "safe" manner").
    Other fuses are to protect downstream wiring only (ignoring discrimination; and undersized fuses that economically match the load).
    Jan 2008
    Quote Originally Posted by OldSpark View Post
    not all amps have fuses on the amp-- some very old amps, some cheap amps, and some newer, very high powered amps do not have integrated fuses(the first that comes to mind is Orions competition sub amps.).
    Nov 2009
    yes the amp has its own fuse. i was talking about the inline fuse for the power wire to said amp. should have been more specific. youre saying the size of fuse there wont make a difference? thanks again.
    Jan 2008
    it should be as close as possible.
  1. Question about software and 92 mazda miata
    By white_commet in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-20-2009, 09:13 PM
  2. Quick question about dvd drive
    By totaleclipse3 in forum Newbie
    Last Post: 10-19-2008, 08:27 PM
  3. A Quick Question.
    By LegacyCore in forum Newbie
    Last Post: 09-08-2008, 07:56 PM
  4. Quick Question About Grounds
    By jzgt in forum Car Audio
    Last Post: 01-29-2005, 06:59 PM
  5. Quick question for any other members (LCD)
    By septicdeath in forum LCD/Display
    Last Post: 01-11-2005, 06:59 AM
