While it is possible to use it as a computer screen in this way, it isn't recommended as the low image quality of rca video can make text hard to read. Also, the touchscreen can't be used with the computer as there isn't a way to connect them.
If you already know this but want to do it anyway, then just try it, but you might find yourself better off getting a VGA screen with USB touch.
There isn't really a standard setup, because it depends on what you want, and car pc's are often built up over time, and this could be a good temporary starting point setup until you know what you want.
LinkBack URL
About LinkBacks
