Remember when posting to include as much detail as possible.
Props for including the model of the case and the mobo
are you running 2.5 drive or a 3.5? dont know if that matters or not.
Power Supply?
I hope your using a slot drive and not a tray. I know it seems silly to ask, if you look at the specs of the case, but there are those people out there...
Are you holding your mouth right when you try to install it?
Did you pray to <insert divine holy higher power/s>?
Did you search the forums? I know fitting in a voompc has been discussed...
Wish it was a TARDIS?
LinkBack URL
About LinkBacks
