Results 1 to 10 of 13
Thread: Lilliput Troubles...
    Oct 2009
    Let me start out by saying that yes I have down a search before starting this thread. I look through various threads that sounded like maybe it was my problem, but all that I read were not related and there are a lot of threads. I did not read though every single one as there were too many.
    OK. So I got my 8" Lilliput 889GL today in the mail. For some reason after calibrating the mouse pointer is still not where it should be after touching my screen. Wherever I touch the mouse pointer will show up just a half inch to the right and lower.
    I have done that 4 point, 9 point and 25 point calibration. Pressed the red bulls eye until I hear the beep...I've made sure that I was extra careful in holding the stylus directly in the middle...
    Anyone have any ideas?
    Jan 2008
    i am no-where near my car, but i think that there might be some things you can adjust in the setup program that is included with the drivers. i know that on my 629 7", i have adjusted the right side youch parameter so that i can scroll web pages easier.
    Oct 2009
    Quote Originally Posted by soundman98 View Post
    Thanks for the reply
    So I looked around some more in the driver program tools and I didn't find anything. What version of the drivers are you using? I have the windows 7 one.
    Jan 2008
    I am using the xp version.
    Hmm, then it might be a bad touch screen controller...
    Oct 2009
    I see...brand new out of the box? Well anyways, is this something common and that probably I can get from Lilliput?
    Thanks for your reply again
    Aug 2009
    Dumb question, but have you tried calibrating it with a slight offset similar to the one you're seeing after you complete the calibration? If nothing else, it'd be worth trying to see if it gives you spot-on accuracy that way, or if it gets even more confused. Good luck!
    Oct 2009
    Quote Originally Posted by Guswut View Post
    I just tried playing around with some settings with edge compensation sliders...didn't do anything. I am afraid I didn't see any offset settings in the egalax...
    But thanks for the reply
    Jan 2008
    i think he is saying that instead of playing with the settings in the setup program, try running calibration again, but press on the screen about the amount of distance that the screen is missing the exact center by..
    Oct 2009
    Soundman98 thanks for clarifying on that, Guswut thanks for the suggestion because I have it about 98% accurate now! I am sure with some more trial and error I will get it right on.
    Thanks again!
    Vendor - Mo-Co-So
    Nov 2005
    You have a monitor with a defective touch controller/panel.
  1. Replies: 7
    Last Post: 01-24-2007, 09:31 AM
  2. My lilliput troubles...
    By Munkeyd00d in forum LCD/Display
    Last Post: 10-28-2006, 01:26 PM
  3. xenarc first impressions, tried lilliput before
    By emdzey01 in forum LCD/Display
    Last Post: 06-09-2005, 06:26 PM
  4. FS: 7" Lilliput Touchscreen VGA Monitor : Broken
    By jaeger in forum Classified Archive
    Last Post: 08-21-2004, 07:46 AM
  5. Replies: 5
    Last Post: 04-01-2004, 04:37 AM
