Results 1 to 3 of 3
Thread: rev and odb2
    Dec 2009
    rev and odb2
    ok my guages are messed up in my car (the needles themselves are bent, not the actual motors and stuff. If possible id like to replace them with obd2 readout. i heard using a program called REV you can get obd2 output onto an iphone. What kind of obd2 hardware would i need to connect it to my iphone? (even if the guages were good id prob do it anyway)
    Newbie Moysie's Avatar
    Oct 2007
    Fife, Scotland
    Blog Entries
    1
    The hardware required to use REV on an iphone is a wifi scantool such as PLX Devices Kiwi wifi LINK
    I take it that you have ensured your vehicle is OBDII compliant?
    Dec 2009
    yes it is, its an acura tls 2002.
    also thanks for the link! i was thinking of mounting a screen infront of the guages and running REV pretty much alwasy when im in the car. on the guage screen for RPM and speedo. im going to try to fix my guages, but a new guage assembly is 300, so if im dropping that ill just do this instead (i have a monitor laying around and im using the iphone to touchscreen adapter kit
