Results 1 to 10 of 16
Thread: 2005 chevrolet cobalt install
    Nov 2009
    Hello, I've been reading on the forums for some time now and have been purchasing components for my carpc build and will soon be ready to install. I'm hoping I'll be able to get help in this thread as questions arise.
    I've already purchased...
    PC
    Intel D945 with atom processor
    1 gig ram
    m2 power supply
    Radio
    Directed HD radio
    Monitor
    Touchscreen liliput EBY701 (waiting for delivery)
    Need to purchase
    4 channel amp (undecided on model)
    power distribution block
    Wiring
    Probablly a bunch of other stuff
    My first question is about the IGN wire.
    The pc, hdradio, monitor, and the amp will all need an IGN source.
    I know there is an available spot in my fusebox to add this(for the optional sunroof), but is it safe to run ALL these devices to the same fuse?
    Oct 2009
    I got the infinity ref475a on ebay for super cheap its 4 x 75 watt RMS and harmonaudio is running the auctions every few hours. My winning bid was $45 but came out to $56 after tax and shipping...its a little scratched up and I havent tested it but I feel good. I'll be installing in a 2002 cavalier so I probably have the same questions as you...lets see who else chimes in.
    Elsewhere
    Quote Originally Posted by FALSE View Post
    I wouldn't.
    Your safest option is to run a power line back to the battery, especially considering the equipment you intend to use (PC, touchscreen, amp(s)).
    How about the Wiki?
    Nov 2009
    Quote Originally Posted by DarquePervert View Post
    I wouldn't.
    I plan on running a power line back to the battery. That would be my always hot line. I'm talking about the IGN wire. Will connecting all the IGN wires from my devices to the same IGN wire be safe?
    Thanks!
    Elsewhere
    For the IGN wire, yeah, probably.
    There's very little current, as it is just used for sensing voltage to trigger turn-on.
    How about the Wiki?
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    Hey False - take a look in the worklogs - my co-worker (cmotors on here) just installed his into his 09 Cobalt. He covered everything pretty well in there in case someone else with a Cobalt decided to do an install.
    Actually - here's the link - 2009 Cobalt - basic straight forward install - simplest route
    The nice thing with this car(I believe it's the same on the earlier versions of it) - is that the battery is actually in the trunk/spare tire well.
    We tapped into the WindowRAP circuit - fuse 17 - so that you've got power for about 10 min after the car is off, unless the door is opened - that's when it'd send the power off signal to the PC.
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
    Nov 2009
    Thanks for the link Sargeants, that definately gave me a few ideas.
    I'm still trying to figure out what size wiring I'm going to need. Just for the computer I used this link http://www.thermaltake.outervision.com/Power to figure that the pc will draw about 74 watts. I'll call it 100 watts to be on the safe side.
    Now to figure the amps you do watts/volts.
    I'm confused how to get my volts. Would it just be 12 volts?
    100W/12V= 8 1/3 amps Right????
    Oct 2008
    Ontario, Canada
    rate your fuses based on the m2 power supply you're going to use. make sure that it can power your system/screen/accessories, or upgrade to a larger/better power supply.
    and yes, the 'average' from the car would be 12VDC
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Rate the fuse based on the wiring you use, and size the wiring based on the power supply. Never put a larger fuse than you wires are rated for, no matter what you have hooked on the end of it. 12 gauge ought to do you fine for the kind of power you're looking at.
    RevFE
    My Shop
    Nov 2009
    The m2 is 160 watts so thats plenty of power for everything I'm running.
    I just wanted to make sure I was calculating everything correctly.
    Does anyone know of a free program to easily illustrate my setup. To make a schematic of all the components and the wiring.
    I was doing it in paint but figure theirs gotta be a better way.
  1. Replies: 61
    Last Post: 10-07-2012, 04:45 PM
  2. Newbie Set on Mac Install
    By The_Blade in forum MacCar
    Last Post: 06-12-2008, 02:16 AM
  3. Replies: 10
    Last Post: 11-20-2006, 05:14 PM
  4. 2005 Mercury Mariner - First CarPC install
    By MileHighCFI in forum Worklogs
    Last Post: 10-10-2006, 08:21 PM
  5. Phase 2 Peugeot 306 Install
    By 306carputer in forum Worklogs
    Last Post: 02-10-2006, 08:00 AM
