Results 1 to 10 of 11
Thread: 4-pin connector on m3
    Dec 2009
    Is there a way to get a 4-pin connector on a M3 power supply?
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by batista08 View Post
    If by "4 pin connector" you mean the P4 Connector, then sort of. The P4 connector was devised since they needed so much juice. Some boards still require it to be plugged in but draw very little.
    If you have a modern board that just needs the connector but in total will not overload the 12v rail of the PSU, then you can just wire the connector into the other wires. If you have an older or a more powerful mobo/cpu combo, then the m3 just doesnt have the umph.
    1.9in x 2.9in -- 47mm x 73mm
    Dec 2009
    Quote Originally Posted by 2k1Toaster View Post
    I will be powering the following with it:
    Asus AT3N7A-I
    2GB DDR2 800 1stick
    WD 500GB
    7" Lilliput 629GL
    GPS receiver BU-353
    PS3 Keyboard
    DVD-rom
    Would it be enough? How can I make the P4 connector?
    Newbie mshowman's Avatar
    Dec 2009
    Parker, CO USA
    If the board has it, usually the bios will complain if you don't connect it.
    You can get something like this:
    http://www.mini-box.com/4-Pin-P4-Power-Cable
    Mar 2006
    Quote Originally Posted by mshowman View Post
    Basically what I was hinting at but much easier to execute
    You need to do your own PSU power calculations. Part of the initiation rights into the CarPC community.
    Dec 2009
    Thanks, I will grab an old psu and make the connection. I'm going to use the m3 for now and order a m4 or find an opus with 150+ watts for a good price.
    I have been doing my research to find the answers to all my questions, specially after seeing how people getting harassed because they didn't search but the whole point of a forum is to help out and answer the same questions over and over. If you get tired of this simply choose to answer those questions you think are worthy of you writing. And I do not mean to disrespect you or anyone with this but sometimes one is in a hurry and just need to be pointed quickly in the right direction.
    Mar 2006
    You were pointed, now you must work. A CarPC with no work, is a CarPC full of frustration.
    Quick answer is you'll be fine.
    Dec 2009
    Thanks. I'm going to hook everything tonight to setup windows and transfer all my data to the carpc. 30k songs and now the music videos download galore will start.
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    You're correct that the whole point of a forum is to help, but not by answering the same question over and over and over and... if that were true, there would be no search feature. What would be the point? Why would there be topic areas? Why would we need mods? You speak of a forum with complete anarchy.
    Usually the same question gets asked over and over because of laziness. If you're in a big enough hurry that you can't research, chances are you're going to end up with a half-assed install that doesn't work.
    You may be wondering in this case why I even bothered to post. Well I don't mean to disrespect you but if you don't do the research and just come here for the quick answer... eventually nobody will want to help you because you are not willing to help yourself. The information really is here already, I promise. And if it isn't, at least you can honestly say you tried before asking a newbie question.
    Tidder
    Try RevFE
    Dec 2009
    Quote Originally Posted by Tidder View Post
    Let's agree to disagree to some extend. I apreciate the help, honestly I do. The point that I tried to make with that post was people don't have to be so aggresive when telling someone to use the search button because not everyone is forum friendly, I am so after couple of weeks of reading I couldn't come up with the answer so I posted my question.
  1. BMW E46 Owners with DSP systems and no HU
    By edrock200 in forum Newbie
    Last Post: 05-24-2012, 11:59 PM
  2. Opus 120 and MTSVO-SC, wiring questions
    By 01black_ac in forum Power Supplies
    Last Post: 03-22-2006, 08:36 PM
  3. Pinout Color Codes / Tables
    By gummybear in forum General Hardware Discussion
    Last Post: 05-12-2005, 04:05 AM
  4. So I cant get my simple LCD to work... :(
    By sirhotalot in forum LCD/Display
    Last Post: 08-16-2002, 11:57 AM
