Odometer with LCD
I'm building a kit car with an Ecotec motor and tranny, I plan to use an 8.4" lcd screen as instrument cluster, I search around to find what will be the best solution to have a separate Odometer, i don't want to rely on the PC/ itx to "store" my mileage of the vehicle, since they have some legalities here.
So I found out that I can use a small LCD as a Odometer and trip. I know the source on VSS, vehicle speed sensor, is 4000 pulse per mile from the OEM, and now a little bet different since I change the size of the tire.
I plan to use this :http://enmco.thomasnet.com/item/enm-...t45a2?&seo=110
as a Odometer but I have only one concern is how I take my pule from my VSS and "tweek" them to match my real mileage, I think i can use a frequency divider but this is as much as I can figure out .
I'm sure some of you has been there, this could even be set to the real mileage but using a frequency generator.
Any help or comment will be appreciated. On comment tho, I have no clue how many miles the motor have since it's stored in the BCM and the ECM do not belong to the motor.
Well I would suggest that you try asking this over in the hardware section, there are people over there that would know a lot more about this sort of thing. Good Luck!
