Results 1 to 7 of 7
Thread: Newbie in need of a carpc. Any advice where to start?
    Jul 2009
    First of all hi,
    I need a carpc for my minibus, has to be small, not very expensive as its an old minibus,
    also is their a system that doesn't turn the PC off every time i start the minibus?
    If possible i would like to have a sun visor monitor but i don't want loads of cables dangling from it. (i.e video,signal etc)
    I was thinking of getting a netbook since all i need the carpc is for internet, audio, and to see some films. Are they any good? Also can they be operated even if they are closed in the glove compartment?
    Damien Falzon
    Constant Bitrate Ramb0_Command0's Avatar
    May 2006
    NW Pennsylvania
    Well Damien, it sounds like you need to do some research. All of the questions you are asking have been covered many times over.
    -There are all shapes and sizes of car PCs, some are very small.
    -It is possible to setup your carpc so that it doesn't startup every time
    -There are flip-down monitors
    -Netbooks are just small laptops, you'll need to do more research to see if they will work for you
    It sounds like you have a long way to go, search, search, search
    Car PC Project Status
    Audio......[====================] 100%
    Computer.[====================] 100%
    Car.........[====================] 30%
    <------ If my information is helpful, give me some rep! The scale thingy :)
    Feb 2010
    Hi Ramb0_Command0
    I'm new here and from Singapore and just joined this interesting forum. Iím very keen to embark on carpc and desperately need guidance and step by step tutorial for carpc and os installation.
    Regards........Cheers
    sleepyjob
    Jan 2008
    this is the best place to start:
    http://www.mp3car.com/vbulletin/advfaq.php
    though, i do not know of any step-by-step guides to building a carpc, because this is based on a hobby that everyone has different requirements.
    oh, and sleepyjob-- you might want to consider changing your picture-- a moderator (tidder) is using the same one, so it could result in you getting a lot of pm's about forum issues, or questions about carpc installations...
    Apr 2009
    harrisburg pa
    Chris from mo-co-so on ebay has some very good systems for great deals... just go to ebay and search carputer. they start at like $269.99 and then you can add what you want such as hard drives, cd drives, sound cards, and so on. Check them out.
    Feb 2010
    Hi Bro soundman98
    Thanks for the prompt reply and guidance. Greatly appreciated.
    As advised, I've removed my avatar............ cheers
    Low Bitrate Belo's Avatar
    Jan 2010
    Buffalo, NY
    as a newbie myself, i will make one comment. Don't limit yourself to a limited, out of date carputer b/c your car is older. A carputer just like a sub and amp can be transferred to a new a vehicle with relative ease. So go for something decent, or you'll be disappointed.
    09 Pontiac G8GT [decently modded]
    former carputer owner, given up for iphone
  1. Need advice on new CarPC setup
    By nfasano in forum General MP3Car Discussion
    Last Post: 12-08-2008, 07:14 AM
  2. New CarPC build on the way, need some advice.
    By citizen604 in forum Newbie
    Last Post: 08-13-2008, 08:03 PM
  3. carpc monitor vibrate at start car engine >???
    By Zo6om in forum LCD/Display
    Last Post: 02-10-2008, 04:37 PM
  4. VW Jetta 99.5 Fastest Start to Finish CarPC
    By mashfique in forum Worklogs
    Last Post: 05-24-2007, 03:28 AM
  5. Another newbie looking for advice on hardware
    By cid_mcdp in forum Newbie
    Last Post: 06-29-2005, 11:47 AM
