Results 1 to 10 of 12
Thread: What battery
    Apr 2008
    What battery
    I am currently putting together a computer for my truck how ever this is not about that, this about a battery for it all, currently I have a yellow top optima battery and I thinking of getting a blue top for the purpose of having battery when the truck is running (yellow) and one that is for when the truck is off (Blue).
    my question is what do y'all think of having the blue top to run things while the truck is off or should I just buy a red top for starting and running the truck and use the yellow to run things while the truck is off
    Low Bitrate Meltz014's Avatar
    Mar 2005
    Denver, CO
    Just curious, how will you switch between the two? I currently have a yellow top in my Accord, and it has done a great job both when the engine is running and when it's off. Of course, i never really use the pc for extended periods while the engine is off anyway. Are you planning on doing a lot of this?
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    If you want 2 batteries I would just use 2 yellow tops then. Then between the 2 throw in one of these: Smart Battery Isolator
    Yellow tops are designed for deep cycle and starting. Reds are good for starting but don't last long when put into sustained loads (from experience).
    Apr 2008
    Yea the isolator was pretty much the way I was going to go but my reason for suggesting the blue top was that that is what is used in boats to sustain numerous electronics and pumps for an extended amount of time so I assumed that it would be better for use when the vehicle is off for use with the sound system
    Raw Wave
    Nov 2009
    You'd probably want a deep cycle wouldn't you?
    In either case it may be worthwhile using a low voltage cutout (battery guardian etc) unless the PSU can do that.
    You could use any battery. I was going to suggest not spending the money on an AGM battery, but if it's in the cabin or boot etc, then AGM it is. (Or a gel cel?)
    And if you can connect to the D+ or charge lamp circuit, don't bother with the "smart" isolators - a charge-lamp controlled relay functions exactly the same. (For a heavy relay, maybe use a BW solenoid that is triggered by a smaller relay that is driven by the D+ circuit?)
    Jan 2008
    how long are you planning on running the system for with the engine off? i have run my computer, and 2 audio amps, at adequate levels on a yellow top for at least 2-3 hours with no issues starting afterward.
    it might be a better idea to first try running everything you plan to run with just the yellow top, and see how long it will last, and then if it is really needed, to add another battery later on.
    Apr 2008
    I guess I should try and run the whole thing here at my house to see more or less how long I can run it without having problems starting it up, but also my whole train of thought here is I guess I am just looking to have some sorta back up
    Nov 2009
    Hello, I saw your conversation regarding our batteries and wanted to help out if I could. uknowwhat, unless you want a group 31 BlueTop, our other BlueTops sizes are identical internally to their YellowTop (D27, D34) or RedTop (34) counterparts. You would need to run an isolator anytime you are using batteries that are not identical in size, type and age.
    Although Optima batteries are a sealed, Spiralcell AGM (not gel) design, it is important that any lead-acid battery has proper ventilation. ALL lead-acid batteries can vent gas. Traditional wet batteries do this immediately when recharged, since they are not sealed. Sealed lead-acid batteries like Optimas and all other “dry cell” AGM batteries have safety release valves that should only vent if they are seriously overcharged.
    Under normal operating conditions, an AGM battery will not vent gas. Since alternators or chargers can fail, the safest and correct mounting method for trunks and passenger compartments is to make sure that any possible gas venting will escape to the outside of the vehicle. All vehicles with original equipment battery locations in trunks or passenger compartments will have a vent provision that should be used. If your battery is custom-mounted somewhere in the passenger compartment we recommend venting the battery to the outside of your vehicle as well. Optima group 27, 51, 78, 34C, and 31 batteries all have ports for connecting a vent hose.
    Although people do it anyway, we would never recommend installing an unvented battery in any enclosed space, because there’s a legitimate, albeit unlikely, safety risk involved.
    For example, IF there is a voltage regulator failure, and IF the battery is severely overcharged, and IF this goes unnoticed, and IF the battery vents because the internal pressure exceeds the release pressure of the vents, the gasses are both flammable and toxic. This may sound like a lot of “ifs,” but attorneys and engineers get paid to plan for every worst-case scenario. If you have any other questions, I’ll do my best to answer them.
    Jim McIlvaine
    eCare Manager, OPTIMA Batteries, Inc.
    www.facebook.com/optimabatteries
    Raw Wave
    Nov 2009
    Glad to see someone else pointing out the venting of AGM batteries.
    It's cute in combination with thermal runaway that isn't uncommon under those circumstances - NOTING that I am used to dealing with AGM stings of 400VDC etc (12V monoblocks and smaller series strings (including parallel) are a far lesser issue!!).
    Though like many battery gurus, I do not like parallel batteries except when monitored, else when new. Though that is not so much of a safety issue with only 2 maybe 3 batteries, but more one of lifecycle - 2 parallel batteries have about twice the unreliability of batteries that are separated when idle.
    Do you have any data/results from parallel versus free standing; and co-housed versus boot & engine bay?
    Jun 2008
    Seattle, WA
    Quote Originally Posted by OptimaJim View Post
    Maybe I read that wrong, but if they are identical internally, then what's the difference between BlueTop, RedTop, and YellowTop?
  1. Measuring Initial Car Battery Voltage Help Needed
    By pblakeney in forum General Hardware Discussion
    Last Post: 11-11-2010, 08:37 PM
  2. should I get a capacitor?
    By dragger5258 in forum Car Audio
    Last Post: 02-01-2010, 05:35 PM
  3. Replies: 2
    Last Post: 05-16-2007, 06:32 PM
  4. time to a dead car battery?
    By chuckctv in forum Newbie
    Last Post: 08-24-2004, 02:47 PM
  5. time to a dead car battery?
    Last Post: 08-20-2004, 10:08 PM
