Results 1 to 4 of 4
Thread: Fuse/Power advice.
    Newbie Danger_MouseUK's Avatar
    Jan 2010
    Fuse/Power advice.
    I'm completely confused with regards to wiring up the power for my carpc.
    I'm going to be running a Dell optiplex 745 with everything stripped out and a laptop sata drive in, and 2GB of Ram in 4 sticks.
    A touchscreen and a USB hub powered from the PSU, with a USB GPS.
    I have an M3-ATX 150 (http://www.itx-warehouse.co.uk/Produ...?ProductID=718), because i couldn't wait for the M2 HV to come back in stock.
    I've bought a wiring kit, which has 10AWG wire, and the run will be aprox 4-5m.
    Now I know i have to put a fuse inline close to the battery, from what i've read, 15amps will do???
    But i've also read that you need to put a fuse in where the wire changes gauges?
    So should i put a fuse between the 10AWG wire from the battery and the thinner wire with the connector that comes from the PSU? If so, what rating should the fuse be? Or do I just pick a fuse that matches that thinner wire, and put that down by the battery and just connect the wires directly together?
    Also, is it fine to ground this to the cassis, or do i have to run a wire back the neg terminal on the battery?
    I am comletely confused by all this talk of watts, gauges and amps... so add words like 'car' and 'huge great big fire' and i want to be right before i start installing. Many Thanks
    Raw Wave
    Nov 2009
    Fusing isn't too difficult....
    Fuses are used to protect "downstream" electrics.
    Equipment should have its own fuse to protect itself - eg, amplifiers, PCs etc. (If not, you supply an external fuse. But some loads don't have their own fuses - eg lights etc...)
    Apart from the loads (equipment, there is also distribution to get it there - ie, cables/wires & junctions for the electricity (current = Amps) to get to the load.
    We connect the wires to a power source - eg, a battery.
    Be place a fuse at the start of the wire as close as possible near the battery.
    This fuse is simply protecting its downstream load - ie, the cable.
    The cable might be rated for 30A (30 Amps) hence we might use a 30A fuse or smaller.
    If we split the 30A cable into two 20A cables further down, then we should have a 20A fuse at the start of each 20A cable. Or 5A fuses at the start of 5A cables. without those fuses, the battery will supply whatever "fault" current (a high current due to overload, or short circuit etc) and melt the wires. A 10 Amp fault current will melt the 5A cables etc. So we have a fuse that melts instead of the downstream cable or equipment.
    I practice we might try to avoid too many fuses. And there are practical considerations like physical security etc - eg, if a section is so well protected it can't short out, we may skip its fuse - provided there is a same-rated or smaller fuse downstream. Or we may decide that fro the battery +12V terminal to the fuse or distribution box/block is so short or safe that we don't need to fuse at the battery terminal.....
    In your case, the ATX3 has a 150W peak output.
    It's input power is hence at least 150W.
    Power = Volts x Amps (current) - ie, P-VI, so I=P/V.
    For 12V, I=150W/12V = 12.5A. So you should have at least 15A, maybe 20A.
    But the you need to add ATX inefficiency etc - maybe for 150W out it uses 180W in.
    And if it works down to 6V, that means I = 180W/6V = 30A.
    If you will only use 100W with a battery no lower than 10V, that's 100W/10V = 10A, so then a 15A fuse and cable is fine.
    FYI - a general rule of for fuses & cables to normally carry no more than 70% of its rating - eg 0.7 x 30A = 21A for a 30A cables & fuse, but 25A and 30A are okay - it's just that there is no spare overhead, and they may run quite warm.
    Also to reduce voltage drops form the battery to your "max 30 Amps" ATX, you might decide to use 100A cable to the ATX or to the last section of 30A cable.
    Rather than using a large fuse for the 100A cable, you could use a 30A fuse since that is all you will be using. (There are some considerations with this - like heavier cable conducting heat away from the fuse, but that shouldn't be a big issue.)
    And voltage and power have nothing to do with fuses EXCEPT for their voltage handling - eg, 240A AC on a 12V fuse might arc across the fuse etc.
    Fuses otherwise are simply rated for current. (Sometimes AC or DC fr BIG fuses.)
    Jan 2010
    I think my head's blown a fuse........
    Thanks, will have a good read through that when i get home and try to wrap my tiny mind around it.
    But, because i'm having such a hard time understanding it all, I don't really trust my judgement, so can someone confirm that a 15amp fuse at the battery is fine for the setup i've described above?
    Raw Wave
    Nov 2009
    15A is fine if you don't exceed 15A.
  1. Small Car, budget complete setup advice
    By Scouse Monkey in forum Car Audio
    Last Post: 07-13-2010, 11:17 PM
  2. Replies: 1
    Last Post: 02-06-2010, 12:25 PM
  3. Replies: 16
    Last Post: 09-08-2006, 09:37 PM
  4. case advice needed
    By michfull in forum Newbie
    Last Post: 12-19-2005, 09:56 PM
  5. need advice on system type - ITX or ATX
    By craigj in forum Newbie
    Last Post: 09-18-2005, 10:03 PM
