bump![]()
As a total newbie I would like to build a PC that will run CF3 efficently (quick startup, no lags, good performance) and would like to also use my nokia n95 handsfree through CF3.
I have space for a double DIN touchscreen display with space behind after taking out factory audio system (CD/tape/radio).
I was originally thinking of using this space for the entire PC, however I have noticed in some threads that nano-ITX systems can cause CF3 to be slow, which something I don't want. I do have room in the back of the car for a larger enclosure and could run leads for screen and USB's to the front. I would like it if the PC was still easy to unhook and take inside when necessary.
Parts I have decided on are;
- joycon steering wheel RC
- Globalsat BU-353 GPS
- HQCTi radio reciever
- Centrafuse 3
Parts I need advice on (most of it) are;
- touchscreen
- bluetooth adapter
- enclosure
- motherboard
- memory
- power supply
- Windows (XP? or 7?)
- microphone (for handsfree only)
- OBD-II scanner (if budget allows!)
- SSD HDD
- USB hub
- amp (as small as possible; using factory speakers)
Thanks in advance for any advice.
p.s. any australian-specific tips are much appreciated
bump![]()
Many of these questions have been covered thousands of times on these forums...
A good place to start would be here: http://www.mp3car.com/vbulletin/advfaq.php
Then search for the dozens of reviews on whatever products you might be considering....and if you have more specific questions i'm sure people would be happy to chime in.
openMobile - An open source C# Front End (why choose openMobile?)
- Always Recruiting Developers -
Like what you see? Donations are always welcome
