Page 4 of 4 FirstFirst 1234
Results 31 to 34 of 34
Thread: How much is too much
  1. #31
    Jan 2008
    Quote Originally Posted by ez_ View Post
    i was looking into other solutions what about solar powerd
    there is a thread in wha i think is the general hardware section by user 'nobb' about setting up a solar panel just for a 5-6watt camera recorder-- and that panel isn't exactly small(don't remember exactly, but i thought he was trying a panel that was almost 20" square)
    and, again, if i remember right, a dual core pentium 5300 is a 65 watt processor-- so, assuming that all of this guestimating is correct, you would need 13 of those 5 watt, 20" square, solar panels just to power up the processor, then you also have a couple more watts for powering the board, hard drive(s), accessories, and will have to account for less-then-optimal-sunlight angles-- so by the time your done, you would need a semi truck trailer with unfoldable solar panels .
    not trying to be so negative, just realistic on power requirements-- i posted my engine off run time, because, until i recently installed the pentium 5300 in my car, i had no idea how much power these computers are sucking--i have always used highpowered computers at home, so i would just plug them into a wall outlet, and they just work, so because of that, i think i desensitized myself to how much power those little buggers suck-- i can throw figures around all day, but until you see your battery go from 13 volts to 9 volts in a matter of 1-2 hours, the power requirements of monster computers become very real. just this alone has me worried-- enough that i am probably going to start carrying one of those battery jumpstart packs, and wondering what i can do to keep the processing power, but limit the power consumption...
  2. #32
    ez_
    ez_ is offline
    Feb 2010
    stockton, ca
    Quote Originally Posted by SGAsgard View Post
    did you realise you have a motherboard with a socket LGA 1156 and a processor with a Socket LGA 775, those are incompatible
    you are 100% rite i posted the wrong mobo
  3. #33
    ez_
    ez_ is offline
    Feb 2010
    stockton, ca
    ok im not sure wat i wanna ask so i will ask thi.
    how would this benefit me
    http://www.engadget.com/2010/04/05/a...ps-pro-models/
  4. #34
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    We use this or similar in my office. They only give about 45 minutes of power and thats only with the CPU connected to it. All the other stuff I had to put on a seperate battery.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
