Results 1 to 8 of 8
Thread: What power supply to use with this
    Newbie Labratd22's Avatar
    Apr 2010
    I am thinking of upgrading from a double din thing my brother bought for me a while ago to something a little better.
    Was think of matching a Preassembled Black Double Din LCD Frame with a ZOTAC MAG HD-ND01 mini pc,
    but was wondering what type of power supply to use with it, either an inverter under the passenger seat or go with one of the power supplies off this site.
    The zotac spec sheet has the power input at 19v DC, would the power supplies on this site be able to handle that or will i be stuck with an inverter?
    Thanks for any help
    Lab
    Sep 2005
    Bay Area
    You can try one of these. It does go up to 19V, only thing will be if it has the proper connector. Can't beat it for the price. I keep one in the car in case I need to power a friend's laptop or anything else.
    Jan 2008
    or you can check for the carnetix unit in the mp3car store.
    Apr 2010
    Quote Originally Posted by soundman98 View Post
    would that be enough to power the pc and the lcd or should i go for the Carnetix CNX P2140 185W one to be sure i have enough juice to run both?
    Jan 2008
    the only thing that worries me is that the 2140 outputs 18.5v instead of 19, so depending on the board, it might not like it.
    i would go with the 1900 version because it says that it outputs 19v.
    Elsewhere
    The P2140 and P1900 both output the same voltages.
    How about the Wiki?
    Jun 2005
    Dubai
    so will the P2140 work with the zotac mag??
    Jan 2008
    yes, it should work fine.
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. REVIEW::220 Watt DC-DC Power Supply: DSATX
    By seabeggar69 in forum Power Supplies
    Last Post: 03-20-2006, 05:53 PM
  3. Shuttle G5 1100h and Opus Power Supply
    By Caelric in forum Power Supplies
    Last Post: 11-16-2005, 05:13 PM
  4. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  5. Power Supply Options?
    By Optikal in forum Power Supplies
    Last Post: 06-26-2004, 06:46 AM
