Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: wanting Double DIN, but also FM on car pc?
  1. #11
    Jan 2008
    Quote Originally Posted by spyrule View Post
    On a side question... amplifier decision:
    Alpine MRP-F300
    Or
    Rockford Fosgate Punch P400-4
    Connected to Alpine 6 1/2" Component set in the front, and Alpine 6 1/2" speakers in the back.
    I plan on eventually having a sub with it's own small AMP seperate (but that's down the road).
    - Spyrule
    my $0.05..(3 more than you want, 5 more than you need )
    either amp shold work fine for normal speakers-- it is kind of personal preferance-- i don't think that you will be able to tell too much of a difference between the 2 in a blind test.
    as for the pro's/cons: a auto amp is typically more expensive than a small 'motorcycle' amp, but usually makes much more power, but are much larger, but the motorcycle amps are reported to be just as good as factory stereos, and are usually less than $100 for a 4 channel version...
    the choice is yours (i don't give brand suggestions for audio equipment-- audio is too subjective to get a reliable opinion in most cases--i prefer to give advice that allows you to make your own decision-- then you can't blame me when it isn't what you want )
  2. #12
    Oct 2009
    Ottawa, Canada
    Quote Originally Posted by soundman98 View Post
    Any suggestion on a good quality 4 channel motorcycle amp?
    (I have to admit, I never thought of this as a solution, so I've done zero research)... some direction/suggestions are welcome.
    -Spyrule.
  3. #13
    Oct 2009
    Ottawa, Canada
    Quote Originally Posted by Pegasus50 View Post
    Thanks for pointing out another reason why it sucks to be Canadian. Thankfully...you still for XM as an option. Good luck with the Habey BIS-6620-I; this looks like a real contender if you can install it successfully. I Hope you'll post a worklog and give us a review.
    Well actually if you think about it, it's another reason to loath the US, since they are the ones who don't follow the standards that the rest of the world follows.... ya know... sorta like metric vs standard,whaddya know... another unique standard for USA only.... just a thought....
    And you sound like getting the Habey to work is a problem... is there something I don't know about that I'm missing?
    - Spyrule.
    p.s. - Btw, up here in igloo land, it's Sirius satelite, not XM.
  1. Double Din Car PC Touchscreen VGA
    By jtreibick in forum General Hardware Discussion
    Last Post: 06-11-2006, 10:54 AM
  2. Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail!
    By hd54321 in forum Power Supplies
    Last Post: 02-24-2005, 01:42 PM
