Results 1 to 9 of 9
Thread: Wiring car speakers to a pc
    Oct 2008
    I've read all the FAQs and searched the forum but can't find the answer I am looking for. I am putting a Dell Mini 9 into my car which will replace the existing head unit.
    In order to get sound to my car speakers, do I need to wire in an amp? I am assuming the pc won't have enough power to feed the speakers. If I do indeed require an amp, can someone recommend a decent unit which is priced reasonably? I am not an audio guy at all and don't need a loud *** system, just a factory equivalent setup.
    Maximum Bitrate jpinkerton's Avatar
    Jan 2009
    Iowa
    Does your stereo have a stereo mini port on it?
    Oct 2008
    I don't have a stereo. The stereo will be replaced by a computer. The computer has a regular speaker port.
    Jan 2009
    Iowa
    Then you'll need to do an amp and output to the amp. That means you'll also want to look at how much beefier of power cable and grounding everything since you'll likely be mounting everything in the trunk.
    The FAQ link in my signature as some charts about figuring power/gauge of wire.
    Elsewhere
    You know....
    There are diagrams and a tutorial for this in the FAQs...
    How about the Wiki?
    Oct 2008
    Quote Originally Posted by DarquePervert View Post
    You know....
    You mean this? http://www.mp3car.com/vbulletin/faq-...-speakers.html
    It doesn't really answer the question whether or not I can power my speakers directly from the computer.
    Jan 2008
    technically, you can power the car speakers by the computer-- but if you want the audio to be any louder than a whisper, you have a couple of options:
    run carpc into headunit using aux input
    run carpc to factory amp
    run carpc to external amp--this really has 2 options:
    small motorcycle amps are less than $100, and are reported to sound as good as factory head units, and are usually super small(some are about the size of a dollar bill)
    larger aftermarket car audio amps are usually more than $100 new, have a larger footprint than motorcycle amps, but have more power, and usually more features for audio control.
    Elsewhere
    Quote Originally Posted by interceptor View Post
    No, I meant he FAQs here: http://www.mp3car.com/vbulletin/advfaq.php
    Several FAQs about audio connections, but the one you want is at the top of the Audio section.
    How about the Wiki?
    Low Bitrate chris_h's Avatar
    Apr 2010
    VT
    The Human Loop
    Finger >> Touchscreen >> Automotive System >> Amp >> Speakers >> Ears
    ^_^
  1. 2000 Mitsubishi Verada Car PC Install
    By MitchellO in forum Show off your project
    Last Post: 01-08-2010, 07:09 AM
  2. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 12:28 PM
