Results 1 to 3 of 3
Thread: Valet Switch
    Mar 2010
    Valet Switch
    Not sure if I'm using the right term or not here but I would like to setup a switch that breaks the power circuit to my computer so that it doesn't always startup when I'm in the vehicle. When I just run up the street I don't want the computer to be just starting up and then immediately have to shut down. My question is I believe the M2atx uses the accy line to detect power so do I put the switch on the accy line to computer or right on the main power line? Also, can I just use a computer on/off switch or do I need something special?
    Josh
    Jan 2008
    your on the right track--most computer switches are momentary-- meaning that they only work when you keep pressure on them. you should look for a normal switch(one that stays where you switch it too)
    once you connect it in the acc line, it should works exactly as you need.
    Mar 2010
    Awesome, I actually got a switch that is meant to power on computer accy's like fans, etc so it's just a straight off/on switch.
  1. this is how to bypass laptop button and standby switch
    By andyman in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 12-18-2007, 03:52 PM
  2. Power Supply/OPUS Kill Switch
    By SpaceMonkey in forum Power Supplies
    Last Post: 08-11-2006, 10:58 AM
  3. New product - PC Power switch with wired remote
    By hd54321 in forum General Hardware Discussion
    Last Post: 03-08-2006, 10:48 PM
  4. Car Window Switch Replacement
    By alienjj in forum Hardware Development
    Last Post: 09-05-2005, 12:08 PM
  5. Savage Switch Botton Group Buy via UK's Iconstyling.com....
    By TheBigDog in forum General Hardware Discussion
    Last Post: 07-21-2004, 10:51 AM
