Results 1 to 6 of 6
Thread: problem with touchscreen mac mini
    Jan 2010
    Exclamation problem with touchscreen mac mini
    i have a mac mini in my car running virtual box to run centrafuse and the touchscreen works when i first boot and then like 10 mins it will just stop working has anyone ever had this problem or knows anything i can do to resolve this problem.
    Jan 2008
    lol, there is another thread in the general hardware area with a similar problem-- he looses all usb devies after 10 min.
    so, what power supply are you using(i think the 2 stiuations are different, just want to make sure), and do you have any other usb devices that are plugged in and continue to work after the TS fails?
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Jan 2010
    i have the carnetix P2140 and there is more things pluged in usb for example my powermate still works and my usb hardrive is still working
    Jan 2008
    in the virtual box, does it still recognise the touch screen after it stops working?
    HID retro--100%
    Jan 2010
    im not sure but i will check and the other thing is if i close out of the virtual box and go back to the mac os and the T.S still does not work
    Jan 2008
    it has been a while since i worked on mac's-- is there something like windows device manager--ie: where you can see what drivers are loaded and if they are working? if there is, i would check that as well(i also haven't worked with VB, but assume that closing and opening it would refesh the devices it is using).
    what about reslotting the touch screen? does it work after doing that?
    HID retro--100%
  1. Mac Mini Hardware Problem...I think
    By Sukh1983 in forum MacCar
    Last Post: 03-17-2010, 07:51 AM
  2. Replies: 82
    Last Post: 11-26-2009, 03:32 AM
  3. Mac Mini in colder seasons?
    By Isthan in forum MacCar
    Last Post: 08-07-2008, 09:30 AM
  4. Newbie Set on Mac Install
    By The_Blade in forum MacCar
    Last Post: 06-12-2008, 02:16 AM
  5. P1900 alternative power supply for Mac Mini
    By johnsin in forum MacCar
    Last Post: 12-07-2006, 09:05 AM
Tags for this Thread
