Results 1 to 4 of 4
Thread: Using a tablet screen for a carpc (lots of questions)
    May 2010
    Hi, I am new to the forum, but have been busy researching here and other places for more information on what I am trying to do. I have a touchscreen tablet donor that I want to build a system around, but I am at a loss when it comes to converting the ribbon to a usable interface (VGA or DVI, or preferably USB). I have a lot of experience in building pc's and car systems, but no experience with modifying displays. I am willing to solder, hack or whatever it takes to get this to work, I just need a direction or some links as far as where to go from here.
    I understand that I will most likely have to buy a usb interface controller for the 4-pin touchscreen cable, but if there is a way around that I'd like some advice as well.
    The guts of my system will most likely be one of the setups I have lying around or my Mini HP.
    The pictures are of the three cables coming from the screen. A high/low power wire, a 4-pin cable for the touchscreen, and a 20 pin cable that I am trying to convert from. If you need more pics, I can take more.
    The screen is a 10.4 inch Philips LC104S1 A1, if that makes a difference.
    Thanks for any help or advice.
    Jun 2008
    Seattle, WA
    365 has 4-wire resistive touchscreen to USB controllers for about $40. That seems to be the easy part. Finding a controller for the screen might be harder. Try searching for LVDS or FPD-Link to VGA (or DVI) converter.
    May 2010
    Thanks for the info. I had found those in another thread on here as well, and I will probably have to go with that usb controller. As far as the screen controller, I have been searching, but to no avail at this time. Do you (or anyone out there) know of anyone that has done this, or something similar? I just need a point in the right direction...
    May 2010
    Okay, so I have found the USB controller I will be ordering, but I still need some help with the display part. I really need some help here, please.
    Do I need to get the whole controller module in the first picture (
    Or will the simple converter suffice? (2nd pic
  1. 2007 Mazda 3 Dash Screen looks OEM
    By Splash-X in forum Show off your project
    Last Post: 05-04-2009, 06:29 PM
  2. Replies: 116
    Last Post: 08-07-2008, 11:23 AM
  3. 330i ZHP CarPC install - HEADUNIT RELOCATED - Lots of Pics
    By Si_g in forum Show off your project
    Last Post: 07-19-2008, 02:20 AM
  4. Replies: 0
    Last Post: 02-12-2008, 11:02 AM
  5. 4:4 vs 16:9 screen res questions
    By NJay in forum LCD/Display
    Last Post: 07-25-2003, 04:52 AM
