Results 1 to 6 of 6
Thread: Leaving a carpc in standby (m2atx)
    Mar 2010
    I am wondering if anyone actually leaves there computer running in some kind of hibernate/standby when not in use rather than shutting down? I have a pretty low draw system using an atom based system rather than a full desktop chip but I still wanted to see if anyone was doing this. It seems like it would be less wear and tear on the system if you could just do this rather than shutdown/boot cycles that go on normally.
    Oct 2006
    most people uses hibernation, and that actually draw zero current.
    standby, if you're using s3 hybrid sleep with windows 7, depending on your psu configuration and your batter could work very well. I'm currently doing it, and i know others who have done it as well.
    Mar 2010
    With either of those settings, hibernate or sleep, have you had many instances of the pc hanging on wake? I seem to have that happen on desktops whenever I try to use those settings and always just end up going back to always on.
    Oct 2006
    not if all your software and drivers are installed properly.
    FLAC SFiorito's Avatar
    May 2004
    search the forums, there are plenty of threads on hibernation and hybrid sleep. I use hybrid sleep every day and don't have any problems either in power issues or hanging.
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
    Jun 2008
    Seattle, WA
    I've been using S3 sleep with Windows XP (no hybrid sleep) every day for about a year with no problems so far. Keep in mind this will probably drain the battery after a few days, but that isn't a problem for me, since I drive every day.
    Hibernate draws no power, of course. But it starts up slower, almost as slow as a cold boot.
  1. P2140 - Drawing to much power in Standby
    By Setesh82 in forum CNX-P2140
    Last Post: 05-22-2010, 11:38 AM
  2. MP3Car CarPC State of the Union 2006
    By SwapMeet in forum General MP3Car Discussion
    Last Post: 10-18-2006, 08:32 PM
  3. Computer doesn't resume from standby...Opus 120
    By senseless228 in forum Power Supplies
    Last Post: 10-04-2006, 06:04 PM
  4. CD head unit remote amp turn-on - Can it be used to trigger standby?
    By mach5 in forum General Hardware Discussion
    Last Post: 06-18-2006, 04:45 PM
  5. Loud noice when turning on CarPC
    By Andreas106rally in forum Car Audio
    Last Post: 11-03-2004, 11:27 AM
