Results 1 to 10 of 11
Thread: Blue screen
    May 2010
    Blue screen
    Hello, I have car dvd head unit InnovateK 868TS everything works fine on the screen. Until I put in a dvd to play, all I get is a blue screen with sound. I have the wire hooked up to the breake. Anyone know what is wrong with my head unit. Thanks
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    If you're sure everything is hooked up correctly, first thing I would do would probably be contact the manufacturer.
    Tidder
    Try RevFE
    Jan 2006
    If the headunit has a reset feature or a sequence of buttons to press in order to reset it, find out how to do it and reset it. This might fix it. Usually the manual will contain the reset procedure.
    If that doesn't work, pull your radio fuse and then put it back in. That should cause it to lose memory and maybe it will work when you put the fuse back.
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    the brake wire should be hooked to ground if you want to watch dvd while the car is in drive also i found that those units are not very good and have a real wonky dvd drive in them. i found only original dvd/cd's or burnt ones on very slow recording speed (2x for example) hope this helps SNO
    May 2010
    I know its hooked up correctly casue it use to work, then one day I got a blue screen when i put a dvd in it. For the radio I could see everything on the screen. Thx
    Jan 2006
    I tend to agree with Snowtwistr.
    Have you tried an audio CD? Does it play at all? Do you see the controls on the screen? (play, pause, next track, etc.)
    If no CD works, the CD drive might be on its way out. You could try using a cleaning CD/DVD in the hope that it's just dusty inside.
    May 2010
    I could play audio CD and it has sound. I see the controls on the screen for radio and dvd (play, pause, next track, etc.) I also use original dvd. Thx
    Vendor - Qube colin's Avatar
    Dec 2006
    You used to play DVDs on it or this is the first time trying? I think you have the wire hooked up wrong.
    May 2010
    I used dvd for before and it work, then oneday i got the blue screen, so i know its hooked up right cause it use to work..
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Double check that the wire didn't come lose or short out.
  1. Help, Navi Causes Blue Screen
    By dhantiflag in forum Software & Software Development
    Last Post: 02-09-2008, 02:01 PM
  2. Tedelex LCD Screen
    By ryanbyn01 in forum LCD/Display
    Last Post: 09-05-2007, 09:46 PM
  3. my poor screen
    By jay_tu in forum LCD/Display
    Last Post: 08-11-2006, 04:19 PM
  4. BLUE SCREEN on my MONITOR!! WHATS THAT MEAN???
    By ironic in forum General Hardware Discussion
    Last Post: 08-05-2006, 03:24 PM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
