Results 1 to 10 of 17
Thread: Carputer - The Next Generation
    Newbie Imobejoas's Avatar
    Jan 2005
    So I built my carputer in 2004 and I've pretty much kept it going until about now. It's still going strong, but I wanted to put a few new software updates to it and now my hardware is clearly obsolete. With a tight budget I want to salvage my parts if I can, especially the case.
    Here's my current setup:
    Morex 3688 Case
    M1-ATX DC-DC Power
    M10000 Mobo
    512MB RAM
    IDE HDD
    I'm thinking of upgrading with an ASUS ATOM board. Not sure which one to go with just yet. I think right now my main concern is the height of the heatsink and will it still be able to fit in the Morex case. If it can't, does anyone know what can? And I think I'm gonna need to upgrade those other elements too, M2-ATX or M3-ATX?
    Mar 2006
    Colorado, but Canadian!
    I have no idea about the Morex case, so I will let others take care of that.
    As for M2 vs. M3, I have both and personally I do not care for the M3. The M2 definately has more options as far as soft/hard off delays. (Without the little programming cable)
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2006
    I'll second that. The M2 is a very good reliable power supply and is sufficient for most car PC installations.
    Have you considered mini-ITX boards? Intel makes a few of them, some of which have the processor soldered to the board. I'm using one and it's great Zotac also make some very good ones with plenty of features (HDMI, optical audio out, onboard wifi, etc.) so those are a great option if you're tight on space.
    Of course, you can great creative and remove the heatsink and design your own thermal management solution.
    Jan 2005
    I'm currently considering ASUS's mini-ITX AT5NM10-I board. It looks like a sufficiently fast enough CPU (the M10000 was good enough) and able to handle the basics of music, GPS, bluetooth, and the like. I think the power consumption should be low too, so the M2 is good enough for me.
    The case that I have is a Morex 3688
    As you can see, the vertical clearance is not much. Basically my old board's components could not exceed the height of the stick of RAM. So I was wondering if the AT5NM10-I board could fit in that case. I haven't seen any pictures for it to see.
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    I have this case, and the inside is TIGHT. I'd be surprised if the ASUS Atom board would fit without replacing the heatsinks.
    Tidder
    Try RevFE
    Jan 2005
    Quote Originally Posted by Tidder View Post
    As long as the heatsink does not pass the I/O shield, we would be in good shape. By the looks of this video, I think it is ok.
    Can the AT5NM10-I be powered by the M1-ATX? It would probably need the P4 plug which isn't native onboard the M1, but could be modified by molex connector? I'm not running a whole lot. Got a slim CDR/DVD, 2.5" SATA 7200rpm (10k? dunno, need to research), and usb devices (mouse, touchscreen, gps, bluetooth, wifi, etc.)
    Sep 2003
    New Mexico, USA
    The video that you linked to isn't the same motherboard? The AT5NM10 on newegg appears to have a bigger heatsink. I would think however for compatibility's sake, it still may not be taller than the IO shield.
    Tidder
    Try RevFE
    Sep 2003
    New Mexico, USA
    Ahh, yeah there should be plenty of space in there. I took mine apart and now remember why it was so cramped in there. I have a jetway motherboard in there with a PCMCIA daughter board. Everything felt so much closer to the top...
    I think it'll be fine.
    Tidder
    Try RevFE
    Apr 2010
    I have ASUS AT3IONT-I Deluxe dual core atom mini itx board with just a small fan on heatsink. It fits inside an M350 case rather well I think. Uses 90 watt power brick.
    Think you'd like it.
    my setup uses:
    MB - AT3IONT-I Deluxe
    Memory - G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333
    Hard drive - Kingston SSDNow V Series SNV425-S2BD/64GB
    Case - M350
    Jan 2005
    Good eye! The difference between the two is the integrated ION features. There's more USB connects on the ION board versus the AT5NM10. But for my purposes the AT5NM10 would/should work. Good, I think I just might carry out this project. =)
  1. My 2006 Scion xB (portable) Carputer setup! w/pics!
    By breaker021 in forum Show off your project
    Last Post: 01-05-2007, 10:34 AM
  2. Carputer confusion- n00b needing help
    By TonyMartin in forum Newbie
    Last Post: 03-10-2006, 01:11 PM
  3. Carputer confusion- n00b needing help
    By TonyMartin in forum General Hardware Discussion
    Last Post: 03-08-2006, 10:43 PM
  4. wikipedia: carputer definition
    By pRoFiT in forum Off Topic
    Last Post: 12-31-2005, 09:32 AM
  5. Good time to buy carputer components?
    By Linus in forum General MP3Car Discussion
    Last Post: 11-25-2004, 09:57 PM
