Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Power Supply for Basic Carputer
  1. #11
    Jun 2010
    Okay guys, that sounds good. Thank you for all of your help!
    Now I just have to decide what gauge wire I will use!
  2. #12
    Vendor - Qube colin's Avatar
    Dec 2006
    Well how much are you powering off of it? If you're running 300 watts from your engine, you could go with 8-gauge and still have room for expansion. If you go farther than say 14 feet, you should upgrade to a 4-gauge.
  3. #13
    Jun 2010
    300 Watts. My grandpa thought I should get a 10-14 gauge wire, but I thought I should get an expert opinion. It's just going from the battery to the wire, so not a very great distance.
  4. #14
    Nov 2006
    Rubidoux, CA
    Honestly, the inverter approach is never going to work well. You'd be far better off getting an actual CarPC Power Supply, that would handle the startup and shutdown of the PC for you. Worth the money, IMO.
    And CarPC's aren't ever the 'cheap' way of doing something...
    2000 Ford Expedition Eddie Bauer - Bi-Fuel Gasoline/CNG
    Intel D945GCLF2 w/512MB RAM, CL Audigy w/KxProject, M2-ATX, Lilliput EBY701
  5. #15
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by Sonsum View Post
    10-14 gauge would work dandy if the voltage was higher - like 120 volts. The lower voltage in the car means you need larger gauge wire.
    Want to:
  6. #16
    Dec 2006
    Agreed. Assuming your inverter is rated at 300 watts, that's not an RMS so 10 gauge could work. It's ALWAYS better to play it safe with electronics though, so I would recommend 8 gauge as your minimum requirement. 8 gauge is sorta cheap too
  7. #17
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Quote Originally Posted by colin View Post
    Uh.. perhaps you are thinking of amplifiers? In a DC power supply application you generally don't look at RMS. That being said, your wire values aren't incorrect. If the inverter is rated at 300w continuous (Let's assume it is, for safeties sake), then you need a wire that is capable of supporting that. At 12v, that's 25amps. 10 gauge would work, 8 is overkill for that level of power, but it never hurts to overkill.
    And as mentioned before, don't forget the fuse properly to your wire size unless you want your car to catch on fire... and cars burn quite nicely
    RevFE
    My Shop
  8. #18
    Jun 2010
    You guys are all the best! Thanks for all of your help!
    I'll try and post pictures of it when I'm done!
  1. What Power Supply for Laptop Install?
    By D3LTR33 in forum Newbie
    Last Post: 08-04-2008, 07:41 AM
  2. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 08:45 AM
  3. New Mpegbox Power Supply
    By zootjeff in forum Power Supplies
    Last Post: 09-20-2005, 01:32 PM
  4. del
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 11:32 PM
  5. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
Tags for this Thread
