Results 1 to 10 of 18
Thread: Carputer finally installed....but it won't boot
    Jul 2009
    B.C., Canada
    Title says it all, here's what I have:
    OPUS 120W PSU
    ON-OFF-ON switch with constant 12V and ACC from the stereo harness
    Here's what I know:
    Power is getting to the 6 wire pigtail.
    PC won't boot with switch in any position.
    Switch from PSU to mobo is installed correctly.
    That's about all I know. I'll try to answer any other questions as best as I can to solve this.
    PROGRESS:
    Hardware: 100%
    Software: 99% - Always upgrading and improving.
    Installation: 100%
    WORKLOG:
    2005 F-150
    Oct 2006
    try to isolate the problem, see if you can plug the mobo into a standard atx psu, and see if it'll boot.
    Jul 2009
    B.C., Canada
    It will.
    I was using an ATX PSU when I was testing and building my skin, then I brought it in again just to make sure I didn't fry anything while I was outside with it and it still works.
    I'm about to remove the rocker switch and connect directly to the ACC and see what happens.
    PROGRESS:
    Hardware: 100%
    Installation: 100%
    WORKLOG:
    2005 F-150
    Dec 2007
    Sydney Australia
    You should have the mb wire connected to COMMON of the switch.
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
    Jul 2009
    B.C., Canada
    Quote Originally Posted by RevheadKev View Post
    It is...well was. I took it out of the equation completely and still no go. I origionally had constant 12V for getting gas or whatever (on right), ACC for normal use (on left) and off for valet (middle/off). The PSU was connected to the common. Now that it's removed it's a moot point anyways.
    I also took the power connector out of the HDD and tested it with the truck running and am getting exactly 0V. It seems power is going into the PSU but not coming out.
    PROGRESS:
    Hardware: 100%
    Installation: 100%
    WORKLOG:
    2005 F-150
    Oct 2006
    any error code (blinks) on the power supply?
    Jul 2009
    B.C., Canada
    Not that I can see. I'm not even sure where the LED is supposed to be. I can't tell by the manual or anything.
    PROGRESS:
    Hardware: 100%
    Installation: 100%
    WORKLOG:
    2005 F-150
    Oct 2006
    there should be at least one light, if it aint on or blinking you could have a blown fuse, or broken psu.
    Jul 2009
    B.C., Canada
    Fuse on the PSU and under the hood still good. Guess I should call OPUS on Monday.
    PROGRESS:
    Hardware: 100%
    Installation: 100%
    WORKLOG:
    2005 F-150
    Dec 2007
    Sydney Australia
    OK, so you have 12V to the mb but what about the momentary input from the usual button ? Have you got that wire connected from the psu ?
  1. Replies: 6
    Last Post: 03-20-2007, 11:16 PM
  2. Carputer installed 1986 Mazda RX-7
    By raspyrx7 in forum Fabrication
    Last Post: 05-19-2006, 01:06 PM
  3. Fully built, ready to be installed carputer
    By captainmorgan in forum Classified Archive
    Last Post: 01-16-2005, 01:40 PM
  4. My Weekend of carputer hell!
    By Sonicxtacy02 in forum General Hardware Discussion
    Last Post: 01-05-2005, 09:19 AM
