Results 1 to 10 of 18
Thread: No idea what power supply to get
    Dec 2009
    Hi there,
    My DC-AC inverter just croaked, and I'm tired of hearing that buzzing sound so I suppose it's time to switch to a DC-DC converter. My problem: I have no idea which one to get! Here is everything (as of now) that will need to be powered:
    Netbook
    External WiFi Antenna
    GPS Receiver
    Lilliput 7" Touchscreen
    External Camera
    I am also considering throwing in another computer that would be dedicated to video recording.
    I don't want a cheap PSU, but I want to spend as little as possible. I would like to air on the side of too much power than not enough. My inverter was 300W, so I assume that I would be aiming at around 320W-360W (correct me if I'm wrong). I was looking at the Opus 360W, which seems nice, but I'm not too sure about the others and how they compare. Any advice? Thanks!
    IHateMayonnaise
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    More information is probably going to be needed as to how everything is hooked up currently.
    Thread moved to the newbie section.
    I think your understanding of a DC to DC PSU is a little off. It sounds like you'd be better off finding an automotive adapter for your netbook and an automotive adapter for your lilliput. Everything else you listed should be powered off either the PC or the car's 12v directly, depending on which products you have. Once you throw in an actual desktop-style PC, you'll need to start looking at DC to DC PSUs.
    Tidder
    Try RevFE
    Dec 2009
    Quote Originally Posted by Tidder View Post
    All accessories (cam, GPS, OBD2 etc) are connected via USB. The computer was connected to it's DC adapter which plugged in to my AC inverter, as did the display (which has a cig input option). How would I go about getting an automotive adapter for my netbook? Would it replace my ac-dc adapter that the unit currently uses or would it go before?
    Dec 2009
    So....any advice? Please?
    Jan 2008
    i second the netbook adapter-- it should (in theory), be able to power all usb devices as well.
    Dec 2009
    Quote Originally Posted by soundman98 View Post
    Thanks for the reply.
    How do I use the netbook adapter to power the system from my car? The adapter is AC-DC? Sorry I'm a newb; I'm good at other things though. If you want I can explain to you quantum physics or differential equations or something
    Jan 2008
    hehe, i have a hard time understanding spanish, let alone quantum physics .
    the netbook adapter should really just be a very basic dc-dc adapter(they usually just plug into the cigarette adapter): it will take car voltage in(9-15v), and output the correct voltage your netbook uses on the charge port(usually 12v?)
    Dec 2009
    As long as you can do (basic) differential equations and maybe a little linear algebra and know that "there is no spoon" quantum physics isn't too bad. Seriously.
    My netbook adapter, the AC-DC one, plugs directly into the wall. I know that all (or most) modern notebook adapters can "adapt" to different input voltages and output the correct ones needed for the computer. However, my comp does not come with a cig adapter, and previously I was going from the cig to an AC inverter to my netbook supply (i.e., DC-AC-DC). I am looking to tap in as directly as I can to the DC power supply without going back and forth between Edison and Tesla.
    FLAC freeflashstuff's Avatar
    May 2008
    Socorro, New Mexico, United States
    Run down to your local Rat-Shack and ask for the 12VDC iGo adapter and brick for your laptop. Will cost ~$30 and will save a lot of hassle.
    After a 2 year break, I'm back! There are so many new and familiar faces here!
    New vehicle, new ideas!
    Chryssi - The Changeling CarPC Project
    Dec 2009
    Quote Originally Posted by freeflashstuff View Post
    I will go to ratshack tomorrow; but for the igo can that power my screen as well? My lilliput has a cig adapter, but I only have one of those. Should I just tap it directly in to the line?
  1. Replies: 0
    Last Post: 07-30-2009, 08:45 PM
  2. Puter won't power up? No idea why
    By MAZDABOY in forum Power Supplies
    Last Post: 04-15-2009, 01:36 PM
  3. Travla AC/DC power supply cable
    By Change in forum Power Supplies
    Last Post: 07-25-2006, 11:04 PM
  4. power supply idea, will it work?
    By ares in forum Power Supplies
    Last Post: 03-10-2003, 09:27 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 10:33 AM
