Results 1 to 6 of 6
Thread: Radio no sound 2002 suburban?
    Jun 2010
    - I have a LS 2002 suburban 2wd "no" onstar, "no" bose
    - Amp is located behind the glove box
    Installed a Sony radio and no sound from the speakers. The radio is connected with an adapter plug from a parts store. There is some dicussion about connecting the misteries pink wire that I cannot seem to find. There is a purple wire going to pin "11" which has no wire to it on the radio side. Pin "11" is associated with "amp sense" on some pin diagrams. I tried appling 12 volts to the pin "11" but still no sound. Appreciate any help.
    Jan 2008
    is the factory amp expecting a high level signal, or a low level signal?
    and fyi: this forum is primarily for installing computers in cars, so audio specific advise is a little on the slim side(though, we try to help where we can).
    Jun 2010
    Low or high level don't know.
    Jan 2008
    low level would use the rca connections on the headunit, high level would use the speaker connections.
    if the amp is expecting a high level signal, and you are trying to use the rca's, this can be one of the many culprits, otherwise, it might be connected wrong..
    Jun 2010
    The factory amp has wires only. So I guess that is high level.
    Jan 2008
    did the adapter have any rca's on it? if not, then it is definitely high level inputs.
  1. Unexplained sound problem
    By lexdiamond20 in forum Newbie
    Last Post: 07-10-2007, 09:30 PM
  2. Replies: 6
    Last Post: 05-19-2005, 09:59 AM
  3. Sound Car radio and Carpc playing at the same time
    By vea_victis in forum Car Audio
    Last Post: 04-03-2005, 12:58 PM
  4. got sound?
    By masch in forum Newbie
    Last Post: 11-17-2003, 10:01 AM
