Results 1 to 5 of 5
Thread: Use ground in radio wiring harness to ground touchscreen and Sirius?
    Jul 2009
    B.C., Canada
    I know this is probably a dumb question but that's why I'm posting it here.
    My OPUS 360W PSU comes with a wire that I can use for devices that require regular power so I want to use it for my touchscreen and Mitch's Sirius adapter. Can I then use the ground from my wiring harness from the stock radio to ground these devices or should I still ground directly to the body of the truck?
    Mitch's adapter is 12V @ 1A
    Touchscreen is 12V @ 0.75A
    PROGRESS:
    Hardware: 100%
    Software: 99% - Always upgrading and improving.
    Installation: 100%
    WORKLOG:
    2005 F-150
    Jan 2008
    for mitches adapter, i think it would be best to keep that on regulated power.
    for the screen-- i can go back and forth-- my install, i have my screen connected to the old radio power-- there is no ground in the harness, so it is grounded to the nearest bolt..
    i seen it said more then once that you should also have your screen on regulated power to get rid of power fluctuations-- everyonce in a while my screen does have lines roll through-- i don't feel like fixing it, so it stays taht way..
    Jul 2009
    B.C., Canada
    I was going to use regulated power on both regardless because I have a power supply that allows me to. I was just wondering if I can use the ground on the radio harness. I'd rather use it because it's close. The closest bolt I can find is quite a ways away.
    PROGRESS:
    Hardware: 100%
    Installation: 100%
    WORKLOG:
    2005 F-150
    Jul 2009
    B.C., Canada
    I'd like to install my PC this weekend. Can anyone tell me if this is a good idea or not?
    PROGRESS:
    Hardware: 100%
    Installation: 100%
    WORKLOG:
    2005 F-150
    Oct 2009
    i read that that might cause a ground loop...so what when i installed I ran the ground back to the opus wasn't much more trouble wire is cheap enough
  1. Replies: 14
    Last Post: 10-02-2010, 10:30 AM
  2. 2004.5 Kia Spectra EX - CarPC / GPS / Sirius / TouchScreen - DONE!
    By EagleTG in forum Show off your project
    Last Post: 05-17-2010, 10:16 AM
