Results 1 to 8 of 8
Thread: Car PC and Driver Information Center (DIC)
    Jun 2010
    I did quite a bit of research on this topic. I am getting a Pontiac G6 GTP - which has a DIC embedded into the radio.
    If you want to install an aftermarket radio you can buy a Metra kit, which allows you to keep the DIC and install a single DIN head unit. If you want to install a double din HU, you must purchase the Metra kit, hack it up and relocate it to the glove box or center console.
    I want to install a Double DIN screen, and was wondering if there is any way to get the Car PC to read and display this information, instead of relocating the DIN. Anybody know of any possible routes?
    Thanks a lot!
    Jeff
    Jun 2010
    Guess nobody has an answer?
    Elsewhere
    You're likely on your own here.
    I am reasonably certain there is no plug-n-play solution for what you want, but that doesn't mean it's impossible.
    Your DIC (an acronym that makes my inner 12 year old giggle) just displays data. The trick is getting access to that data and representing it on a screen.
    Assuming I'm correct about the lack of an "easy button" type solution, you'll need to figure out which wires in the harness carry that data, then determine how the data is transmitted, what protocols are used, and how the data is formatted.
    Once you have all that, you'll need to make an adapter or cable to the PC and write software to interpret the raw data and display it on the screen for you.
    Think you're up to it?
    How about the Wiki?
    Jun 2010
    If I had the means and knowledge to do so - then I would be up to it. LOL - but sadly I do not. =(
    Thanks for your reply.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quick for "Pontiac G6 GTP dic" gives me this thread on a Pontiac forum.
    Looks like it is GMLAN based on CANBUS.
    Jun 2010
    I remember reading something along those lines somewhere, but it really doesn't mean anything to me. Thanks though! =)
    Jun 2010
    Thats a hell of a lot of reading! I'mma get to it ASAP! Thanks a lot for your help! Much much appreciated.
  1. 1994 Peugeot 106 XS beeing upgraded just a bit
    By boelle in forum Show off your project
    Last Post: 10-16-2010, 01:41 PM
  2. 1998 Cadillac Deville Concours Install COMPLETE!!!
    By quantum in forum Show off your project
    Last Post: 03-20-2010, 10:28 PM
  3. 97 Pontiac Sunfire Car PC Worklog
    By Nois3 in forum Worklogs
    Last Post: 06-23-2008, 02:36 PM
  4. Installing car PC in 1996 Honda Civic
    By PredatorCoder in forum Newbie
    Last Post: 08-18-2005, 07:58 AM
  5. UK Legality of Car PCs
    By stevieg in forum General MP3Car Discussion
    Last Post: 03-13-2005, 04:41 AM
Tags for this Thread
