Heh good work..
Flash for ie or for firefox..?
Hmm if you are bench testing then yeah you might have issues.. i assume the cable isn't looped or crossing too many wires?
i guess you could try shielding it somehow.. Aluminium?![]()
i'm still bench testing so far, got everything as separate as possible
I'm trying to install RR to see how it looks with everything running etc.. but stupid thing is telling me flash isn't installed.. even though i just did it.. grr
ok.. fixed flash..
Heh good work..
would that work? Though i don't think it's interferencejust a crap cable.. wasn't cheap either..
Installed RR and it doesn't look TOO bad if you don't look too close...
Oh well if anyone says anything i'll just keep driving out of town and drop them off
Or just spend $100 on another cable...
I originally install the flash player..
second time round i installed the flash activex plugin for ie..
Would guess that second one would be what it wanted..
I tried RR but couldn't figure out how to make it do anything useful like install a skin so gave up on it and haven't touched it since..
As for the shielding thing, no idea that's why I said it the way I didgoogle it and see if it would work, may may not..
what do you use as a frontend then?
Do you have the Venice7 radio module? i do and RR seems to have the best support for it.
Still in the desiging phasesProbably looking at getting the DBA radio but I probably have till the end of the year to change my mind another 10 times..
For a start I will probably have winamp and ozi explorer running manually![]()
http://i53.tinypic.com/vdjn15.jpg
not as good as i'd hoped, but close enough for now..
Looks neat enough
top right hand corner sticks out a little.. like it's twisted![]()
Can't tell from the pic![]()
